05-03-2016, 05:12 PM | #1 |
6 Volt Horn Power Needs Model A & Others
I've just gone through all the previous posts regarding amp requirements for 6 volt Model A horns. The consensus is that it takes 5 amps to blow the horn, with some estimates as high as 10 amps. Why the large variance? My question regards a 6 volt E. A. Laboratories Model S, how many amps does it require to blow?
05-03-2016, 05:37 PM | #2 |
Re: 6 Volt Horn Power Needs Model A & Others
it requires enough haha.
Many reasons can factor in amp draw - how tight the adjusting screw is (aka one mans ahooga may not be anothers), if the motor bushings have lube and aligned, how good of contact the brushes have to the comutator (poor contact has high resistance and amps must go up to do the same job), how good of contacts the wires going to it have, how clean grounds are etc. id imagine even new they would vary a bit.
05-03-2016, 06:37 PM | #3 |
Brattons sells a horn relay that mounts inside your horn cover and eliminates any horn drag
Double Click on photo to enlarge view Last edited by Mikeinnj; 05-03-2016 at 06:39 PM. Reason: add info |
05-03-2016, 06:53 PM | #4 | |
That seems to cover it.
05-03-2016, 06:57 PM | #5 |
The relay helps with bad grounds. Resistance from a bad ground, like in the horn button, drops more voltage with high current. The relay uses very low current to switch the current for the horn. So the same resistance will operate the relay but would have made the horn sound bad.
05-03-2016, 11:23 PM | #6 |
