08-04-2018, 07:39 AM | #1 |
1933 Brake Equalizer Cross Shaft
I am working on restoring my brake system and trying to figure out if the cross shaft needs to be rebuilt. How do you tell if it needs rebuilding? Does any company offer this service?
08-04-2018, 08:58 AM | #2 |
Re: 1933 Brake Equalizer Cross Shaft
Wear, if excessive will show up with front-to-back looseness when grasping the two ends with the bracket held in a vise or still in place on the center cross member. The original bushings are sort of a fabric material and best replaced with impregnated bronze or nylon. I know of no one who offers the service, but any competent machinist should be able to do it. The biggest part of the job is getting it apart starting with drilling out the rivets holding the arms on to the ends of the shafts (unless you are lucky and it is a early '33 with easy-to-remove tapered drive pins like '32 instead of rivets.)
08-04-2018, 11:04 PM | #3 |
We rebuild pedals frequently, too. Early V8 Garage 626-338-2282 (Southern California) [email protected] Ask for my dad, Richard.
Early V8 Garage - West Covina, CA |
