01-10-2015, 05:15 PM | #61 |
Re: Engine Rebuilder on ebay
How's that engine from Bert's working out for you. Thinking about ordering from them.
04-09-2018, 08:29 PM | #62 |
References needed: I am going to have an inserted B engine built and need up to date advice.PLEASE . If you have recent experience with an engine builder, good or bad...please contact me or provide your number for me to call.
Thank you very much! George King Huntsville Al 256 520 4401 cell [email protected] email |
04-09-2018, 09:08 PM | #63 |
Welcome to the asylum George!
04-09-2018, 09:45 PM | #64 |
What's the latest on the "T". https://fordbarn.com/forum/showthread.php?t=67881
04-09-2018, 10:39 PM | #65 |
Why not start a new thread with your questions instead of hijacking this thread? I'm sure you will get a better response.
04-09-2018, 11:11 PM | #66 | |
I don't agree with that, James. If you have a pan rail that is warped by a few thousandths, and many are, you can not surface the block correctly, as the block will teeter, or will pull down at an incorrect angle. Also the same reason for the boring of the cylinders., they have to be with the center line with the crank. Vern has done two Model T's, and one Model A already this year, buy surfacing the pan rails, along with the three Mains part line. You just can't leave them like that. This does not affect the center distance what so ever. The first thing you should do is , the boring bar has to be set dead center between the two main bolt holes, on no. 1, and 3. That measurement should never again move, and if it does, it should be, redone, and kept there. The next step the boring bar should now ONLY be moved up and down, for Center distance, while the bar is still dead center between the main bolt holes The only thing that could change is the stack of shims, under the caps. I have always used .032 thousandths, and it never has effected anything what so ever. Herm. |
04-09-2018, 11:25 PM | #67 |
04-09-2018, 11:29 PM | #68 | |
04-11-2018, 12:44 AM | #69 |
I have heard nothing but good things about the Turlock builder.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
06-10-2019, 07:17 PM | #70 |
Here is my Inserted engine with Pressure oiling, Counterbalanced B Crank, Riley head, Yada, Yada, Yada. Just finished by Joe Sivils at Turlock Machine. Joe Sivils runs a one man shop. His attention to detail is superb.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? Last edited by Chris Haynes; 06-11-2019 at 12:32 AM. |
