Old 04-05-2023, 06:00 PM   #1
CA Victoria
CA Victoria's Avatar
Default Headliner Patterns
I am looking for a cad drawing or tracing from a 1935-37 ford pickup headliner.
Or if you have an old one that was removed with enough remaining to make a copy from.
Thanks!
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 04-08-2023, 02:08 PM   #2
OldGold360
Default Re: Headliner Patterns
Doesn’t the factory headliner have a compound shape to it? What are you planning to do?
OldGold360 is offline   Reply With Quote
Old 04-08-2023, 02:31 PM   #3
CA Victoria
Although I did not install it, the one I bought for my other 35 pickup came rolled flat in a box as did the one for my 50 F1. I installed the F1 headliner, it was cut from a flat piece.....
I don’t remember exactly how the rear was cut but it wasn’t press formed into a compound shape. The side pieces folded down Above the doors and the back folded to meet the rear wall panels. Seems like the back was scored to fold & had a radius.
I have nothing to go from now, if the fella who offered a pattern doesn’t come thru I will make my own patterns and see where I end up
Tim
Downtown, Ca
Old 04-08-2023, 03:10 PM   #4
OldGold360
I’m going to be in this same situation soon on my ‘36. Where did you get the headliner for your other ‘35? Did it not fit correctly?
Old 04-08-2023, 03:23 PM   #5
CA Victoria
I’m not sure where it came from but probably from the mfg that is extinct now.
I sold the pickup with the headliner in a box.
The headliner in my 50 F1 came from D. Carpenter, it fit well, I hired an octopus to help put it in.
Still checking but I have yet to find any board with a pressed in pattern.
Tim
Downtown, Ca
