09-21-2023, 10:49 PM | #1 |
Holley b94
Does anyone know where to get jets for a Holley 94/? Speedway sells adjustable main jets but that's all.
09-22-2023, 09:19 AM | #2 | |
Re: Holley b94
09-22-2023, 12:53 PM | #3 |
Re: Holley b94
I think they are the same jets that the Holley 4bbl uses, available online or local speed shop if you have one.
09-22-2023, 12:54 PM | #4 |
Re: Holley b94
Brent, I notice in the pictures, you have friction shocks in the front. What kind of shocks did you use in the rear?
Thanks, Herb |
09-22-2023, 03:52 PM | #5 | |
Re: Holley b94
Back then, I tried various types but as I recall on the rear in those pix I was using front shocks off of a 1970's ½-ton Chevrolet pick-up which were installed at about a 45° angle. I used those because I was trying to use them to control body roll. Those friction shocks up front were about the same as having nothing. Disclaimer: Knowing what I/we know today about race shocks, and if we had a shock dyno and a spring smasher in-house (like now) where we could have tuned with compression & rebound valving, I likely could have made all of my Model-A racers much quicker. Again, back then I was pretty naïve about the concept needing to keep all 4 tires on the ground at all times around the track. The car below kinda took the place of my Model-A race cars. . |
09-22-2023, 04:21 PM | #6 |
Re: Holley b94
09-22-2023, 04:56 PM | #7 |
Re: Holley b94
Well depends I guess. I am building a 1912 Model-T Speedster for a customer that we are fabricating a set of Hartford replica friction shocks. His car will be a street-driven car that has quite a lot of era goodies. I doubt it will never be driven on a race track in 'competition', therefore the friction shocks (-which were the best at the time) will suffice. In the case of when I was driving Big Cars, Speedsters, and Track Roadsters with AARA and DAARA, even though it was called 'exhibition racing', the term exhibition had different meanings for different competitors within the same race!!
09-23-2023, 05:34 PM | #8 |
Re: Holley b94
Brent, thanks for the added info.
09-24-2023, 07:28 PM | #9 |
Re: Holley b94
Brent, What engine mods did you make to run two 94s on your banger. I keep hearing that it's too much carb for a Model A. My motor is .060. over, "B" cam, counter balanced crank and lightened flywheel and V-8 clutch. I'm waiting to get either a Winfield 7.1 head or something similar. This motor goes in a similar speedster as yours shown.
09-25-2023, 04:05 PM | #10 | |
Re: Holley b94
I ran several different ignition systems during that time, and all were similar except the mags. In one of pics, you will see a Model-A distributor that had a Pertronix Ignitor set-up and whatever coil they recommended. Likely the best was with the Mallory Unilite distributor that had a Blaster Coil and a MSD 6AL box. The worst was a WICO mag, and I also had a Scintilla Vertex mag that had great crowd appeal but I wasn't a fan. The bottom line is if you can have good hot spark where you can 'light' the fuel mixture cleanly, then you can run a fat mixture successfully. If you can hide an MSD box, then you can generally run less timing and still make good power. And, ...your bearings will love you for that!! |
