Old 08-25-2018, 08:13 AM   #1
Habusailor
Habusailor's Avatar
Default Overdrive
My 49 custom does not have overdrive, I see a lot of shoeboxes came with OD. What is the best way to convert to overdrive?
Sent from my SM-T550 using Tapatalk
Habusailor is offline   Reply With Quote
Old 08-25-2018, 09:45 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Overdrive
Most cars of that era were set up to go either way but you will have to find a 1949 or 50 overdrive transmission first. The 1951 units may work but they are different and might lead to a need for some modification. If you find one, you will need to purchase a wiring harness, a control relay, a kick down switch, a lock out cable, and what ever transmission components that might be missing from the transmission itself like the governor, reverse lock out switch, or operating solenoid. The driveshaft may work as is but I'd have to confirm that from the chassis parts book for the shoe box Fords.
Old 08-25-2018, 09:54 AM   #3
Cecil/WV
Cecil/WV's Avatar
Driveshaft is the same!
Cecil/WV is offline   Reply With Quote
Old 08-25-2018, 10:01 AM   #4
Mike51Merc
Mike51Merc's Avatar
The best way?
Seriously?
Mike51Merc is offline   Reply With Quote
Old 08-25-2018, 11:21 AM   #5
itsa52
itsa52's Avatar
I have a T86 with OD that needs a new home, but missing solonid, Should fit, although splines may be different.. Brst way is to watch eBay not uncommon for someone to offer the whole shebang, but shipping will be high
itsa52 is offline   Reply With Quote
Old 08-25-2018, 11:37 AM   #6
itsa52
itsa52's Avatar
Not sure what is different with the 51, I know 49/ 50 convertibles with X frame had a special mounting plate for the soloniod so it would clear the frame but sedans where the same.. These trannies all the way up into the early 60's will interchange, May need different clutch plate or drive shaft yoke as the splines were different in some of the later years. Also the taild shaft length may change
http://www.vanpeltsales.com/FH_web/F...ngpawlassy.jpg
Old 08-25-2018, 12:38 PM   #7
tubman
tubman's Avatar
The transmission mount on a '51 is in a different location than the '49-'50. I think it is further forward. This change was done to accommodate the new for '51 Fordamatic transmission. I am in the process of converting mine and was pleased to see that most of the ancillary parts (cable, kick-down switch, wiring harness, etc.) are readily available and relatively cheap. This is not the case for some of the transmission components (solenoids, etc.).
tubman is online now   Reply With Quote
Old 08-25-2018, 02:51 PM   #8
Alaska Jim
Alaska Jim's Avatar
Well, in my opinion, the very best way to make the conversion would be to find a donor car that had all the parts. a rusted out dented up vehicle from a farmers field would be best, but these are very hard to come by any more. putting one together from a part here and a part there may take a while, but is doable. there are many here on the ford barn , and over on the Hamb, that will be able to help you with specific questions.
Alaska Jim is offline   Reply With Quote
Old 08-25-2018, 03:01 PM   #9
leon bee
Maybe watch craigslist for a while, I see them sometimes. There's one on Springfield, MO. list now. Way too far for you, but gives an idea.
leon bee is offline   Reply With Quote
Old 08-25-2018, 04:02 PM   #10
speedshift
If you want a contemporary hiway speed cruiser, get the od transmission and keep your 3.73 rear. Just watched the od conversion installed in a 51 coupe. Took three old f--ts a weekend laying on a concrete driveway. Ouch! You could always do a "parts wanted" and have the pick of the liter.
It is worth the effort and the bucks. Good luck.
speedshift is offline   Reply With Quote
Old 08-25-2018, 05:26 PM   #11
Greg58
Greg58's Avatar
I changed my 50 to overdrive earlier this year, 49 and 50 used the same transmission, 51 will work but you'll have to modify the mount. I used a 51 trans and had to weld a short section onto the mount. The mount is wider and heavier on the 51 and as was said earlier the mount is one inch farther forward. Take some basic measurements of the output of your stock unit, center of output to the tunnel and to the frame on either side. I did this and had to make clearance for the solenoid, measurements make it a lot easier. I bought a kickdown switch but haven't installed it because mine doesn't need it, overdrive makes a big difference in the car, I can run with traffic with no problem.
Greg
Greg58 is offline   Reply With Quote
Old 08-25-2018, 06:51 PM   #12
Greg58
Greg58's Avatar
Member alanwoodieman had a transmission when I was looking for mine, he may still have it. The link below is when I did mine.
https://www.fordbarn.com/forum/showthread.php?t=239339
Greg
Old 08-26-2018, 09:06 AM   #13
Frank Miller
Frank Miller's Avatar
As said before you need to go with the 49-50 transmission. If the reverse lockout switch is bad just bypass it. That was the official Ford replacement part. You have a sedan so you will not need the rocker assembly to mount the solenoid underneath. These transmissions are available as I've seen quite a few at Hershey before. The other parts can also be sourced. Some will tell you they use a toggle switch but when you get one of these hooked up the way the factory did it you'll love the operation.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 08-26-2018, 09:49 AM   #14
rotorwrench
The lock out switch is not just for reverse. Personally, I like to have that switch on there and operational. When you pull the lock out cable, it turns the system off so that the solenoid is not hot when the governor reaches shift speed. I think Ford discontinued its use because owners rarely locked out the overdrive function. If you pull a trailer or live in mountainous areas, you will find more of a necessity to lock out the overdrive and that solenoid uses a good bit of electrical power whether its locked out or not without that switch.
Old 08-26-2018, 11:31 AM   #15
Greg58
Greg58's Avatar
I use a toggle switch to turn the power on and off, I too didn't want unnecessary wear on the solenoid/relay when not using overdrive. The relay I'm using can be found at any parts store, since mine is 12v, my solenoid I found on eBay for $51 delivered.
Greg
Old 08-27-2018, 12:34 PM   #16
amodel25
amodel25's Avatar
The '51 transmission is a bolt in in '49 and '50 if you use a '51 rear crossmember.
amodel25 is offline   Reply With Quote
Old 08-27-2018, 05:26 PM   #17
tubman
tubman's Avatar
I suspect that you have to drill the proper holes in the "X"-member to mount the '51 cross-member; I don't think they're already there. That might get a little tricky.
Old 08-28-2018, 08:31 PM   #18
Greg58
Greg58's Avatar
The mount needed a 3/4 inch rise to sit at the height of the stock transmission, a piece of angle steel cut down on one side and welded to the mount and the the holes drilled. This was the best option for me, I've got maybe $20 in it and it works fine.
Greg
Old 08-29-2018, 09:15 AM   #19
Frank Miller
Only the convertibles had the X member. They also have a rocker attachment so the solenoid is underneath the transmission.
Old 08-29-2018, 01:39 PM   #20
tubman
tubman's Avatar
I should have said "cross member", not "X member"; it may have been a poor choice of terms. I was referring to the inner frame structures to which the transmission support bolts. Since the support has been moved, new holes will still have to be drilled.
