Old 11-14-2022, 09:34 AM   #1
dross02466
Question Radiator removal
Good morning all,
I am removing an old radiator from a 1929 Tudor and I have some questions.
What are the general steps to follow?
Do you remove the front bumper for easier access?
Do you remove the headlight bar attached to the fenders?
There is very little room between fan and radiator.
Any hints are welcomed!
Thanks in advance,
Don
dross02466 is offline   Reply With Quote
Old 11-14-2022, 10:45 AM   #2
Rob Doe
Default Re: Radiator removal
Cover the radiator with a protective, fairly heavy cardboard. Before you do anything. The fins are very fragile and look awful when crushed.
The lights on our coupe had to be unwired and the conduits removed, removing the lights was a 30 second job per side. I did not remove the bar, but it would have been fairly easy. Going back together is not so easy, but doable.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 11-14-2022, 10:49 AM   #3
Gary WA
Gary WA's Avatar
drain radiator, remove top bottom hoses,remove hood/rods,I place cardboard between fan and radiator Remove lower two,bolts/nuts/cotter keys, remove! No need to remove light bar / bumper.
www.whidbeymodelaclub.com
Old 11-14-2022, 08:40 PM   #4
Bill G
Bill G's Avatar
Certainly no need to remove the bumper. Gary WA outlined it pretty well. If you have the Les Andrews book, it is outlined there too.
Bill G is offline   Reply With Quote
Old 11-14-2022, 11:29 PM   #5
Brentwood Bob
Measure spacing/length of both radiator support rods so you don't have to realign your hood when you reinstall everything.
Brentwood Bob is offline   Reply With Quote
Old 11-15-2022, 07:08 AM   #6
Ramman
I usually only loosen the outer forward nuts for the radiator service. Loosen the outer nuts on both ends for engine removal.
Ramman is offline   Reply With Quote
Old 11-15-2022, 01:56 PM   #7
Gary Karr
Gary Karr's Avatar
If you also remove one of your hood shelves, you can easily remove your radiator without having to rotate it in order for the mounting brackets to clear the shelves.
Gary Karr is offline   Reply With Quote
Old 11-24-2022, 12:42 AM   #8
whirnot
whirnot's Avatar
I always remove the bumper first. It's only two bolts and then you don't have to reach over it.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 11-24-2022, 10:41 AM   #9
katy
katy's Avatar
Is the fan on a '28-'29 closer to the rad than the one on a '30 - '31?
Old 11-24-2022, 08:46 PM   #10
31a
I remove the bumper takes about 5 minutes then you have more room to work, saves the back.
31a is offline   Reply With Quote
