07-01-2015, 01:08 PM | #1 |
How much water consumption is normal?
Hi,
I would like to know something about average radiator water consumptions. For instance, is it normal to add 1-2 quarts of water after lets say 200 mi of highway driving? Lucas |
07-01-2015, 01:40 PM | #2 |
Re: How much water consumption is normal?
I might consume a Qt in that mileage, but, I don't want my vehicle doing that.
07-01-2015, 01:45 PM | #3 |
where are you keeping the coolant level at when cold??
07-01-2015, 02:05 PM | #4 |
We need the answer to Mitch's question. The other important factor is, does the level eventually stabilize at some level that's sufficient to keep the car from overheating? If you're trying to keep radiator topped off with little empty head space, most Model A's will throw out a quart or two long before you get to 200 miles. Mine stabilizes at 1/2 to 3/4 inches above the rad core, as measured with a Starbucks stir stick. That level is below the baffle and out of sight, hence the need for a dip stick.
07-01-2015, 02:36 PM | #5 |
I just added 4 oz after a 1335 mile trip...yes i think you have added to much, but let it seek its own level and check the temp
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
07-01-2015, 03:45 PM | #6 |
Lucas |
07-01-2015, 03:47 PM | #7 | |
put it at baffle level or just below COLD |
07-01-2015, 05:16 PM | #8 |
Is the baffle that inclined piece of sheet metal that basically obstructs the view of the core?
07-01-2015, 05:22 PM | #9 |
07-01-2015, 05:52 PM | #10 |
I returned from the 2015 NWRM in Walla Walla logging over 900 miles with several days in the 100 plus. My water level remained unchanged, and I did not add any!! The water level is just slightly above the baffle
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
07-02-2015, 10:32 PM | #11 |
I add a cup or two each year.
07-02-2015, 10:46 PM | #12 |
With an overflow tube in it, why is that not the level to fill cold ? It would level out after the first running of the engine. After cooling back down, wouldn't that be you level?
I have a 1938 tractor with an open cooling system. (non-pressurized ) I fill it until it overflows the tube , then let it level out on it's own, but I check it all the time. |
07-02-2015, 10:50 PM | #13 |
I haven't checked mine in 6 months. It never changes.
07-03-2015, 05:45 AM | #14 | |
For those who only used water, you won't be wasting antifreeze but can expect cracked blocks from freezing weather and rust along with the problems it causes. |
07-03-2015, 08:17 AM | #15 | |
07-03-2015, 10:27 AM | #16 |
With a good sealing stock cap, NO mess on yo' car!
Bill W.
07-03-2015, 10:35 AM | #17 |
until it comes out of the overflow and gets blown all over the chassis and motor from the road breeze..
but then the ole nail trick will stop that |
07-03-2015, 11:16 AM | #18 | |
Bikemanic, it happened in my car BUT the coolant was going out the overflow tube. Broad headed nail fixed that (thank you Bill Williamson). Recently, the vaunted leak-less water pump started dripping. I'll have to replace it. I use a small hand held infrared thermometer to tell what the temps are at the top of the radiator and spots on the motor. After your engine first comes to operating temp give it a read and then again when your coolant finds its level. If the temp rises much you have a leak. |
07-03-2015, 05:10 PM | #19 |
My two driver Model A's with a mix of water and anti freeze receive an annual bottle of rust inhibitor and never need anything else added. I flush and refill with fresh anti freeze mix every 6 years. The rust inhibitor in anti freeze wears out long before it loses its ability to protect from freeze up.
07-04-2015, 07:37 AM | #20 |
I think the the answer to the original poster's question is: If you fill the radiator to just over the tubes, you will have to add maybe a cup or so a year due to evaporation/etc.
