Old 11-06-2023, 07:59 AM   #1
Jeff Norwell
Jeff Norwell's Avatar
Question 57 Merc Steering Wheel>>>57 Ford Column
I have a friend who has a very nice 57 2 door sedan(Fairlaine) and he wanted to use the beautiful 57 Mercury steering wheel on his 57 Ford.
I am not certain, but I believe the spline count on the wheel and the Ford Column will match... but then there is the horn question.As we know a stock 57 Ford horn wiring travels straight up through the centre of the steering shaft.
I have no idea how a 57 Merc is wired ...... but looking on the underside of the 57 Merc wheel.... the horn contact seems to be on the outside... not the centre like a 57 Ford.I personally do not have a 57 Merc Manuel.
Anyone ever seen this done before or any solutions?
Jeff Norwell is offline   Reply With Quote
Old 11-06-2023, 09:22 AM   #2
Ford blue blood
Ford blue blood's Avatar
Default Re: 57 Merc Steering Wheel>>>57 Ford Column
Found this link, scroll down to page 17. Sounds like the horn wire runs down the column cover vice down the center of the column like the Ford.
http://mercury1957.com/pdf_files/cha...ercury1957.pdf
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 11-06-2023, 09:43 AM   #3
Jeff Norwell
Bill....you are a Gem.I will pass this info along to my friend.
thanks Bill.
Old 11-06-2023, 07:27 PM   #4
Daves55Sedan
Daves55Sedan's Avatar
Not sure, but I think you may need to use '58/59 Ford horn contact plate that goes directly under the steering wheel and mounted in the steering hub. Those had the horn wire terminal routed thru a bushed hole in the contact plate off center, rather than poking up thru the middle.
Note also that the manual trans and Fordomatic trans cars had different steering hubs so you need to get the contact plate that fits your hub.
Daves55Sedan is offline   Reply With Quote
Old 11-07-2023, 10:01 AM   #5
Jeff Norwell
I believe you are correct Dave
And thank you.....
