Old 10-26-2011, 01:32 PM   #1
fisheasy
Default gas fumess
I was wondering if someone could point.me in the right direction. When i drive my flat head particulary in 1st and 2nd i smell gas fumes. Anyone know what may be causing that? I can ride in the car for 5 mins and smell gas all over my clothes when i get out also
fisheasy is offline   Reply With Quote
Old 10-26-2011, 01:38 PM   #2
Slick Willy
Slick Willy's Avatar
Default Re: gas fumess
check for leaks that may be small and that the fan is blowing it back into the car, making it an aerosol. The slower the speed the more concentrated it will be.
Slick Willy is offline   Reply With Quote
Old 10-26-2011, 02:11 PM   #3
fisheasy
Well its new tank and lines, also new fuel pump and stand. What do you mean about the fan? The radiator fan?
Old 10-26-2011, 04:12 PM   #4
Slick Willy
yes
Old 10-26-2011, 04:20 PM   #5
fisheasy
Ok i will check. I was wondering if exhaust maybe leaking
Old 10-26-2011, 04:25 PM   #6
John Kennedy
John Kennedy's Avatar
Or blow-by gasses. Is this a new problem, or always since you got the car?
Building a 29 Sedan on 32 chassis........ very slowly....
John Kennedy is offline   Reply With Quote
Old 10-26-2011, 04:29 PM   #7
Henry/Kokomo
Henry/Kokomo's Avatar
Check for obvious and sizable air leaks into the car. I had some holes in the firewall that were admitting lots more air than I would have guessed. It doesn't cure the problem but may lessen the symptoms.
Henry/Kokomo is offline   Reply With Quote
Old 10-26-2011, 04:32 PM   #8
fisheasy
Well i cranked the car up and put my hand in the engine bay. Sure enough strong gail force winds blowing back towards the firewall. I assume that can be fixed?
Old 10-26-2011, 04:33 PM   #9
fisheasy
Its been like that since i had it. Only had the car a month and a half
Old 10-26-2011, 07:32 PM   #10
Ken Crans
Ken Crans's Avatar
Put a trouble light on the engine compartment in the dark and see if you see light coming in the interior. i had a problem like that but it was an exhaust leak. Good Luck
Ken Crans is offline   Reply With Quote
Old 10-27-2011, 10:45 AM   #11
Karl Wescott
Karl Wescott's Avatar
Find the fuel leak first, before it finds a source of ignition and you have a nice fire (make sure your fire extinguisher is readily available and servicable). "Slick Willey" suggested a small leak becoming an areosol, this seems likely and as pressurized would be from the fuel pump to the carb.
Karl Wescott is offline   Reply With Quote
Old 10-30-2011, 06:47 AM   #12
B_man_Al
B_man_Al's Avatar
If your problem is blowby gasses, I've found adding a PCV valve makes a world of difference. My experience is with a 4 cylinder model B, so its not directly applicable, but I drilled a hole in the side of my oil filler pipe added a grommet and installed a PCV valve. (In a 4 cylinder, the vent is also the filler). A better solution might be sealing off the oil filler cap and adding another inlet vent on the valve cover, but I found that what I did was sufficient to get rid of the smell inside the car .... a happy wife makes for pleasant touring.
I drilled a new vacuum port in the intake, on the vertical section above the carb. Originally I used a Tee off the wiper port, but was advised that I might burn a valve on #4 because of a leaner mixture there.
Al
B_man_Al is offline   Reply With Quote
