03-17-2020, 09:26 AM | #1 |
12 volt ignition coil
I have heard that using a 12 volt ignition coil with out a resistor for a points ignition is Ok to use on a 6 volt system. Thoughts or experience?
03-17-2020, 11:19 AM | #2 |
Re: 12 volt ignition coil
I've done that w/out problems, best is to check the primary resistance of the coil, should be aprox 1.5 ohms.
03-17-2020, 11:30 AM | #3 |
My opinion.
If it is a true 12v coil with 3 ohm primary, it will probably work. However the spark may not be as strong, and if wear/deposits occur may cause the motor to run poorly and combustion may not be as efficient. If running a 6v ignition system, best to run what it was designed for with a 1.5 ohm coil primary |
03-17-2020, 01:30 PM | #4 |
Lots of experience.
It depends on the resistance, 3 ohm is fine. 1.5 ohm is not. Install the coil, turn it on with points open, measure voltage. Anything over 8 volts will burn the points quickly. So, if you get an over-voltage install the resister. Its probably best to just get a 1.5 ohm epoxy filled coil. The Pertronix epoxy filled coil will work nicely and looks fine. 6v, 1.5 ohm part# 40111. 12v, 3 ohm, part# 40611. I think I have the part #'s correct, the info would be on their website. Last edited by Patrick L.; 03-17-2020 at 06:26 PM. |
03-17-2020, 07:20 PM | #5 | |
Umm - He is asking about putting a 12 V coil on a 6 V system, therefore he should use a 6v 1.5 ohm coil. If he uses a 12v 3 ohm coil on 6v he will have less current in the coil. have a weaker spark. I do not think that will burn the points or damage teh coil? Or perhaps I do not read the response correctly. |
03-18-2020, 04:25 PM | #6 |
03-19-2020, 08:27 AM | #7 |
When 12V systems came out in the mid 1950s, ignition coils remained the same for 6v systems, but external resistance was added. When starting the car, the add-on resistance was bypassed to give the coil a 12V boost. Once the engine started and the ignition key went into the run position, the extra resistance was cut-in so the coil ran on 8v.
Bob Bidonde |
03-19-2020, 08:50 AM | #8 |
i was told that a 12v coil is ok on 6v , but on 12v it needs the resistor ..
FSI ignition on mine . 12v with resistor
V4f |
03-19-2020, 10:14 AM | #9 |
Actually , a six volt 1.5 OHM coil can be used on 12 volts if a resister is used . The resister prevents the full 12 volts from entering and burning out the 6 volt coil . In other words a three OHM coil can be used on 12 volts without a resister . If a 1.5 Ohm coil and resister is used on 12 volts the ignition will still be running 6 volts , The starter and lights will get 12 volts .
