Old 01-09-2013, 02:37 PM   #1
rickyz
Default new brakes
I would like to replace the standard brakes on my 57 bird with power disc's.
Can anyone recomend a good vendor for the complete parts kit, including all lines ?
rickyz is offline   Reply With Quote
Old 01-09-2013, 08:36 PM   #2
paul2748
paul2748's Avatar
Default Re: new brakes
The TBird vendors have kits. Some come with oversize rear cylinders to compensate for the front discs so you don't need a separate proportioning valve.
Old 01-10-2013, 12:33 AM   #3
Gerry
Gerry's Avatar
http://orangecounty.craigslist.org/pts/3378292547.html
I like this kit. Spindles stay the same doesn't lower the front and not that expensive.
(not my stuff, no horse in this race)
Gerry is offline   Reply With Quote
Old 01-10-2013, 01:46 AM   #4
JeffB2
JeffB2's Avatar
Old Irishmans Auto Parts, Dave McCabe (575) 544-4729
JeffB2 is offline   Reply With Quote
Old 01-13-2013, 11:20 PM   #5
nascardave
Hi, I have bolt on disc brake kits for your t bird, also have drop spindles and disk brakes. Your choice of drop 1 1/2" or 2 1/2" also have dual master with power brakes for your t bird. Keep in mind that you will have to relocate your battery to the trunk if you go with power brakes. If i can help give me a call. Dave 818 572 5302 drop"em & stop"em
nascardave is offline   Reply With Quote
