02-25-2014, 07:44 PM | #1 |
Pinholes in Oil Return Pipe
I just received a used oil return pipe that appeared to be in decent shape, but when I removed the rust I noticed several pinholes in the pipe. How difficult would it be to repair these, and what's the best approach? I'd prefer to fix it here at home where I have a small torch. The garage where the car is located has an oxy-acetylene torch, but I won't be there until Saturday. I'm moderately skilled with both.
If a fix is impractical, I'm sure I can get another one. |
02-25-2014, 07:54 PM | #2 |
Re: Pinholes in Oil Return Pipe
Bert's in Denver probably has a ton of them.
Pluck |
02-25-2014, 08:07 PM | #3 |
you could braze the pinholes. lowes or home depot have the rods for a few bucks. however if you add the time and cost of rod, it may cheaper to get another one
02-25-2014, 08:19 PM | #4 |
Solder will work. The end cups are soldered on on many of these.
Joe K
Shudda kept the horse. |
02-25-2014, 08:22 PM | #5 |
The problem is, I added an oil filter kit that requires the later oil return pipe that's an inch longer than the one that was already on it. I couldn't find it at any of the parts house, but I might not have looked hard enough. But I was able to find someone with a used one of the right size. I'll check Bert's to see if they have it.
02-26-2014, 08:01 AM | #6 |
