Old 04-27-2024, 01:27 PM   #1
FwJ1941
Default 1941 Ford 1/2 Ton Frame & Suspension
City: Osceola
State: Iowa
Price: In Add
For Sale: 1941 Ford 1/2 Ton Pickup Rolling Chassis. Rear End Gear Ratio is believed to be 3:78 with a stamping of “9 34” just below pinion. Tires P205/75 R15 Tread is good with date stamping 33 & 34 of 2015. Included with the frame / suspension is the gas tank, 4 Speed transmission (granny gear) steering wheel, column with switch & the steering gear box. Also the inner fender V shaped bracket that bolts to the frame. Heater assembly that did not appear to have any leakage and with working fan.
You will note steel plates welded to frame just before rear wheels.
Reduced to $700.00 Or best offer for all of the above in a complete package. I’m ready to deal on this as I’m out of room and need to move it. Shoot me an offer and let’s see if we can come together. Still have hope that the components will be of use to restorers!
Please advise me with any questions that you may have.
Frank Jones
[email protected]
641-340-1508
Thank you!
Last edited by FwJ1941; 05-01-2024 at 04:41 PM. Reason: Reduced price from $800 to $700.00
FwJ1941 is offline   Reply With Quote
Old 05-01-2024, 06:50 PM   #2
FwJ1941
Default Re: 1941 Ford 1/2 Ton Frame & Suspension
Bttt
