04-16-2014, 08:24 PM | #1 |
installing a motometer
I have a repro radiator in my 1930 rpu, I was wondering if anyone ever drilled a stock cap and installed a motometer in it instead of the locking cap, even after grinding the base the locking part doesn't seem to fit right, thanks, Jim
04-16-2014, 11:02 PM | #2 |
Re: installing a motometer
Yes, I have a couple original caps that someone drilled holes in them for the motometer.
04-17-2014, 08:13 AM | #3 |
Tom,
Sent you a PM.
04-17-2014, 08:49 AM | #4 |
I put one in a repro cap but I had to make new tabs because when you drill the hole it ruins the tabs. I found some stainless steel and cut it so the center was wide enough to drill a hole rounded the end of the tabs to match the original and it works great. I just worry that someone may borrow it in some parking lot and leave me stranded. I am going to carry an extra cap in my trunk just in case.
04-17-2014, 09:00 AM | #5 |
I've lost a number of radiator caps over the years to souvenir hunters (thieves).
04-17-2014, 10:23 AM | #6 |
I would ether find a cap that has the hole in it or buy a new cap so a good original is not messed up by putting a hole in it. |
04-17-2014, 10:30 AM | #7 |
I have a repo motormeter and had to do a bit of grinding with a dremel to make it fit right, but with some trial and error I got it to fit the way it should. I'll try and post a picture later of what I had to do.
Aaron in Tacoma (although still a Montana hillbilly at heart ) |
04-17-2014, 10:32 AM | #8 | |
My first Motometer worked like a swiss watch. It was a marvelous tool but lost to a thief at a high school football game. The current motometer with the lockable cap has prevented many attempts to pocket it. BUT the darn thing does not register heat. I'm not able to connect with the radiator fluid 'cause of the height. All of the suggested fixes for this havent worked. I miss that orginal gem. |
04-17-2014, 10:44 AM | #9 |
04-17-2014, 12:15 PM | #10 | |
I've never lost a cap, but someone at the 1984 National in Portland stole my Zenith 3 right off the car, and replaced it with a crappy Z-2! I couldn't fiigure out why my car was suddenly running so poorly until I lifted the hood and saw what happened. National and regional meets always make me nervous, and I never drive my A's to swap meets.
04-17-2014, 01:39 PM | #11 | |
04-17-2014, 02:22 PM | #12 |
Not that it's any big deterrent, but I typically don't leave my hood open at shows, and am usually close by, or next to a friend who is, all the time (except when it's time to eat.) Not 100%, but so far so good.
04-17-2014, 07:15 PM | #13 | |
04-17-2014, 08:33 PM | #14 |
Re; " BUT the darn thing does not register heat. I'm not able to connect with the radiator fluid 'cause of the height. All of the suggested fixes for this havent worked. I miss that orginal gem."
Moto-meters don't come in contact with the water in the radiator, they measure the air temp above the water. |
04-17-2014, 09:56 PM | #15 | |
In 1956 my moto-meter registered the temp perfectly if it did or didn't sit in the water, I can't remember exactly. But it worked. I miss it. I knew when to put a piece of cardboard in front of the radiator or clean the plugs or set the timing. Some one lifted it. Now it don't work but it has a locking cap which is why I still have it. |
04-19-2014, 07:52 AM | #16 |
My dad (now deceased) told me once that he use to steal hood ornaments off of cars back in the late 20's to early 30's to fund his cigarette habit!
04-19-2014, 08:03 AM | #17 |
Jim
I would use the correct repro flip top cap If you loosen the heg screws that hold the tabs a little , and locate the cap with the hinge to the back , I would suggest then using a pair of bent needle nose pliers with the cap open and locate the tab properly so it pulls up square in the locators and tighten carefully the hex screws . When both are tight you shouldn't be able to rotate the lower base This way your cap is tight and no one will walk away with it. All radiator necks Aren't located the same so there may be some challenges Good luck Larry s I know you asked about drilling but I would recommend against that and use the flip top |
04-19-2014, 08:55 AM | #18 |
I filed the bosses where the screws go to hold it to the radiator, it finally fit, let the truck run for about an hour and it never got over 150 degrees on the top of the radiator and 140 on the bottom, I don't have a thermostat, I used a pyrometer. It is a new repro radiator, rebuild engine and rebuilt water pump, and I ground the corners of the impellers down a little. So I guess I am good to go. The gauge on the motometer never moved should that be hot enough for it to work or will it be just for looks? By the way it is made by Vintique
04-19-2014, 09:30 AM | #19 |
Motometers and quail radiator caps are mostly ornaments and seldom function as a temperture gauge. The flip top caps always ruin the filler neck so that original caps will no longer fit. I recommend an inside mounted temperature gauge, I prefer the mechanical sending unit style. A good working temp gauge is probably the most important gauge to have and can be removed without damage to the car.
04-19-2014, 10:43 AM | #20 |
My Repro Quail works. My A has never overheated so haven't tested it definitively but on a hot day, running hard, I start to see the red in the bottom. Slow down a bit, it dissapears again. Got mine from Mac's a couple years ago, I've been happy with it. I raise quail so the quail cap is fitting. Sure looks good from inside the car to see that quail flying ahead of you....OH I MISS DRIVING THE A!!! THIS WEATHER IS GETTING REAL OLD!!!!! Going to get it out in two weeks, I don't care what the weather is like!
