Old 03-17-2024, 10:13 AM   #1
Steves46
Steves46's Avatar
Default Stop Leak
Has anyone added Barr's or Lucas oil stop leak products to their engine oil? Did it help to a degree with any leaks? I tried checking previous threads but couldn't locate anything specifically addressing this. Thanks.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 03-17-2024, 10:28 AM   #2
katy
katy's Avatar
Default Re: Stop Leak
Oil stop leak products are for engines w/synthetic material seals, like neoprene for example. With age and heat the seals tend to stiffen up, lessening there ability to seal against the moving (revolving) part. The "oil stop leak" softens up the sealing materiel. It won't help if the parts are worn, causing the oil to leak out the excessive clearance.
I doubt that they would work on a Model A with "old timey" seals.
Old 03-17-2024, 11:35 AM   #3
The Master Cylinder
The Master Cylinder's Avatar
Or no 'seal' at all like the rear main.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 03-17-2024, 03:11 PM   #4
nkaminar
nkaminar's Avatar
A little bit of oil leak is fairly common. Lots means it needs fixing.
Old 03-17-2024, 03:23 PM   #5
ronn
I prefer mine with the fixins!
Old 03-17-2024, 08:30 PM   #6
Jyromefedx
The main question is where the oil comes from and then determine how important/ necessary it is to fix. Rear seal YES, Valve cover, MAYBE?
Jyromefedx is offline   Reply With Quote
Old 03-17-2024, 09:39 PM   #7
jeepguy1948
(A) Most Model A motor’s are happiest about a 1/2 quart less oil than the dipstick indicates. I would suggest that you stop adding oil until it gets that level or even a bit lower. If it keeps leaking after that then it’s time to did deeper. (B) Since there is no rear main seal if you park facing uphill the oil is going to drain out the back just like it will if you overflow the bathtub.
jeepguy1948 is offline   Reply With Quote
Old 03-18-2024, 05:26 AM   #8
nkaminar
nkaminar's Avatar
I never fill my bathtub with oil.
Old 03-18-2024, 06:01 AM   #9
Steves46
Steves46's Avatar
Thanks for the inputs Gents. I believe the issue is the rear main leak from a full dispatch. Will keep it at least half full on the stick.
Old 03-18-2024, 08:19 AM   #10
marty in Ohio
marty in Ohio's Avatar
The old Model A adage is "if it ain't leakin' it's empty."
Marty
marty in Ohio is offline   Reply With Quote
Old 03-18-2024, 08:55 AM   #11
The Master Cylinder
I bet you don't park your bathtub facing uphill either.
The Master Cylinder
Old 03-18-2024, 10:41 AM   #12
Phil Brown
Phil Brown's Avatar
Agreed with the above info on a stock set-up A, but if you have a modern-type rear seal that drips a little or your modern ride leaks 3-4 oz of regular brake fluid in the crankcase (with the motor oil) will swell the seals enough to stop your leak most times.
No need to waste your money on expensive oil stop leak additive, grandpa knew all of the tricks
Phil Brown is offline   Reply With Quote
