Go Back   The Ford Barn > The Swap Meet > For Sale > Late V8
Old 05-07-2024, 12:02 PM   #1
30TS
Default 1956 F 500 Truck for sale $850
City: Walnut Grove
State: MN
Price: $850
1956 F 500 Truck. $850 Sheet metal including body, doors, hood and fenders are good solid condition. Not perfect, some limited rust at bottom of doors, some minor dents, and dents in cab roof.
Tires are weather checked and old but hold air. 20" 5 bolt split rims, but not the “widow makers”
Grain box with a hoist. Wood in the box is bad. No tailgate. Drive shaft is bent, but comes with a replacement.
Engine has been replaced with a 1954 239 y block from a car. Carb has been rebuilt. Engine turns over with the starter but I have not identified why no spark at the points. Four speed transmission. Does not have a two-speed rear end.
Pictures tell the story. Solid sheet metal on a complete truck. If you only want the sheet metal for your pickup project, that can be arranged. Located near Walnut Grove, Minnesota. $850 Thank you for your interest.
30TS is offline   Reply With Quote
