Old 05-19-2010, 08:12 PM   #21
Retro Jim
Retro Jim's Avatar
Default Re: Trans options?
I had forgotten all about the FMX . That was a far better trans than people would give credit for . Very strong too . Well why not a 3 speed w/overdrive or even a good rebuilt Ford O Matic ? There are endless transmissions that can be bolted up to your Y block . You can even get a Chevy trans to bolt up if you are that crazy !
Now I am a die hard Ford guy so please don't throw anything at me for saying something about bolting Chevy trans to a Ford engine
I was just explaining all the options .
Personally I would either go with a C4 because they are easy to find , cheap and very durable or an AOD for the overdrive . If you don't really need the overdrive then go with the C4 !
Jim
Retro Jim is offline   Reply With Quote
Old 05-20-2010, 12:02 AM   #22
Chalupa55
Chalupa55's Avatar
I've got a C4 with the adapter from Mummert. Works good.
A bad day surfing is better than a good day at work!!!
Chalupa55 is offline   Reply With Quote
