02-17-2018, 01:21 PM | #1 |
Pcd
Can someone tell me the pcd on a 19inch wheel '30 model a ?
Need to make an adaptor for a trailer project Thanks
It is a pile of shit bit it's my pile of shit |
02-17-2018, 01:34 PM | #2 |
Re: Pcd
pcd ??
02-17-2018, 01:47 PM | #3 |
Re: Pcd
I may be off here but I think you are looking for the bolt pattern (pcd?). It is 5 bolts on a 5 1/2 circle. There is however another problem. The mounting surface is at two levels, see http://www.fordbarn.com/forum/showth...=1#post1286293
Charlie Stephens |
02-17-2018, 04:44 PM | #4 |
Re: Pcd
In addition, the wheel carrier is not mounted to the frame, it is body mount. While this might have worked back in the day, there is no way that I would want to hook a trailer up that way today.
02-17-2018, 04:58 PM | #5 |
Re: Pcd
I'm with REDMODELT. I have fitted a towbar to one of my As by using the bumper mounts. That worked well but I'd never ever ever try mounting any towing attachment to the spare wheel mount.
Oh, by the way, PCD is "Pitch Circle Diameter". Someone said that the 5 studs are on a 5 1/2" circle. In that case, the PCD is 5 1/2".
02-17-2018, 08:20 PM | #6 |
Re: Pcd
02-17-2018, 09:25 PM | #7 |
Re: Pcd
PCD=Pitch Circle Diameter. As Charlie says, for a Model A it's 5 1/2"
All steel from pedal to wheel Last edited by Dick Steinkamp; 02-18-2018 at 06:20 PM. |
02-17-2018, 11:04 PM | #8 |
Re: Pcd
At least here in the states there are a ton of cars/trucks that used the 5 on 5 1/2" bolt pattern.
I too say you should make a seperate bar connected directly to the frame to tow with
1929 Model AA - Need long splash aprons! |
02-18-2018, 01:16 AM | #9 |
Re: Pcd
Huh? I didn't see Rene say anything about attaching a trailer to the spare tire carrier. Am I missing something here?
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
02-18-2018, 02:57 AM | #10 |
Re: Pcd
For a trailer hitch, I bought one of these from Wagner Products. Bolts right on to the rear bumper supports.
02-18-2018, 03:49 AM | #11 |
Re: Pcd
Thanks all,i already have a trailer hitch/tow bar attached to the bumper mounts,and i tow a modern trailer with the A.
Now i want to build a matching trailer,i have bought a trailer frame with axle. This trailer has a brake system i want to use,but the brake drums are 4 bolt pattern so i need to make a spacer from 4 bolt to 5 bolt so i can nuse the model A wheels,thats all. Greetinfn from a freezing Amsterdam,René
It is a pile of shit bit it's my pile of shit Last edited by René W; 02-18-2018 at 03:57 AM. |
02-18-2018, 01:53 PM | #12 | |
Re: Pcd
02-18-2018, 06:51 PM | #13 | |
Re: Pcd
02-19-2018, 02:06 PM | #14 |
Re: Pcd
I have somewhat the same problem with a trailer I bought. I am going to put Model A wheels & tires on it that match my pickup. Fortunately, the spindles on the trailer will accept Model A hubs, so my plan is to just switch the hubs out. I have already located one hub, just need to get the other one & do the work.
02-19-2018, 05:34 PM | #15 | |
Re: Pcd
By the look of it your trailer has no brakes and that will make it easier to find a hub that fits. I have already a trailer with no brakes and it is no problem pulling it with the A loaded with 2 veteran motorcycles,tent,camping gear in the trailer,wife 2 dogs and me inside the A..........but stopping is another ballgame. As i live in a crowded area of Holland sometimes you need good brakes to avoid them idiots in their BMW's and Mercedeses who think they own the road,so that's the reason i want a trailer with brakes,just for safety reasons. The frame i bought is a former folding camper trailer,can be loaded to 750 kilo and that is enough for me,with that weight there is no need for registration or tax and you can build your own model,model A that is.....
02-19-2018, 10:39 PM | #16 | |
Re: Pcd
02-20-2018, 03:17 AM | #17 |
Re: Pcd
Surge brakes it will be.
02-20-2018, 03:23 AM | #18 |
Re: Pcd
Fun another one I have never heard of.
I guess your surge brakes are over ride cable brakes to us . |
02-20-2018, 03:32 AM | #19 |
Re: Pcd
And as regards PCD, I only learnt a few years ago to measure PCD on a 5 stud wheel, for a good ballpark figure, you measure from the outside of one stud across to the middle of the other farthest stud.
True PCD is centre to centre only on an even studded bolt pattern as in 4/ 6/ 8 etc. I caught an old dude at a swap meet trying to say that his chev wheels were ford PCD and he measured centre to centre 5 stud and got 4 1/2 inch. I took the time to explain to him how to measure it , and all I got was the dumbest stare ever. |
02-20-2018, 05:42 AM | #20 | |
Re: Pcd
About the five stud pcd....i know how to measure it
