Old 03-19-2024, 07:48 PM   #1
Kube
Kube's Avatar
Default beneath the'31 PU floor mat is???
Guys, is there any type of matting directly beneath the rubber floor mat within a '31 PU?
How about some type of seal around the pedals / steering column? I do have the authentic metal plate.
Thanks!
Old 03-19-2024, 08:49 PM   #2
Bob C
Default Re: beneath the'31 PU floor mat is???
https://www.snydersantiqueauto.com/p...7788&cat=41699
Old 03-20-2024, 06:37 AM   #3
old31
There is not any matting under the floor mat.
Old 03-20-2024, 07:39 AM   #4
Kube
Kube's Avatar
Thanks fellas!!! I keep learning
Old 03-20-2024, 07:44 AM   #5
ronn
thought you were going to say-a 20 dollar gold piece!
Old 03-20-2024, 09:30 AM   #6
nkaminar
nkaminar's Avatar
Beneath the floor mat is the floor board and beneath that is the transmission.
Old 03-20-2024, 09:52 AM   #7
Canton_Model_A's
Canton_Model_A's's Avatar
It could have possibly been the 'Window Sticker'
1929 Model A Tudor
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 03-20-2024, 10:04 AM   #8
Joe K
Joe K's Avatar
A hinge and a door to maintain the battery?
Well, one hopes.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 03-20-2024, 10:06 AM   #9
rotorwrench
rotorwrench's Avatar
Ford only sealed around the edges of the floor boards and that column & pedal plate had the felt pad. They didn't use a jute mat pad yet like they did in later years. The throttle pedal rod had a grommet that was tacked to the floor boards. The battery inspection cover plate and the transmission cover plate weren't sealed. I guess they figured that the floor mat would seal all that. Some folks use the lever boots and some don't. They do help keep the dust out.
Old 03-20-2024, 02:30 PM   #10
Kube
Kube's Avatar
You bring to mind yet another question... did the brake lever originally have a boot?
Old 03-20-2024, 10:24 PM   #11
mass A man
mass A man's Avatar
Not sure, but I seem to think the very early '28's with the brake handle on the left side had some kind of a boot. All the later A's had no boots on brake handle and shift tower.
They sell them and I use one on my emerg. brake but not on my shift tower. The rubber mat is made close around it so that keeps a lot of dust out. The felt padding piece around the pedals worked for me for about a year, then it was worn out with big gaps around the pedals. Replaced it once and same thing happened. I give up.
mass A man is offline   Reply With Quote
Old 03-21-2024, 01:38 PM   #12
rotorwrench
The felt may need some type of preservative applied to the edge areas that are exposed. Felt can deteriorate over time. Perhaps some type of oil or grease would help. Leather might have been a better seal than felt but that's only speculation.
Old 03-21-2024, 09:29 PM   #13
mass A man
mass A man's Avatar
Thanks rotorwrench, I may try some of that "flex-seal" or other types of coating on the felt padding. Sorry Kube, didn't mean to hijack your thread.
Old 03-23-2024, 09:16 AM   #14
Planojc
Planojc's Avatar
Kube are you restoring this model A with the same quality as your 39 and 40 restorations or are you just doing a driver? Would love to see some pictures.
Planojc is offline   Reply With Quote
Old 03-24-2024, 06:37 PM   #15
Kube
Kube's Avatar
I'll try to get some photos posted ASAP.
No restoration at all. Just putting together a truck that's been stored in pieces for over fifty years.
I'm having a lot of fun, learning a lot and must tell ya, much less stressful than doing a full (proper) restoration.
