11-21-2020, 08:03 PM | #1 |
speedo cable lubrication??
putting my '30 fordor back together now after a llooonnnngggg hietus. speedometer was working ok when dismantled. should i lubricate the cable somehow or just leave it alone?
11-21-2020, 08:06 PM | #2 |
Re: speedo cable lubrication??
Spray can of' Chain & Cable Lube'
11-22-2020, 11:48 AM | #3 |
I would remove the cable from the housing, clean both the cable and the housing interior w/solvent or diesel fuel, coat the cable w/chassis grease and re-install the cable in the housing making sure that the new grease coats the housing interior completely.
12-02-2020, 02:55 PM | #4 |
I've always used powdered graphite to lubricate speedometer cables. Make sure you put plenty down inside the housing and that should do it. Grease attracts dirt and can harden.
12-02-2020, 08:15 PM | #5 |
I use lithium grease and have had exceptionally good results.
12-02-2020, 08:55 PM | #6 |
12-03-2020, 08:47 AM | #7 |
As mentioned earlier, clean with a solvent and lubricate with a graphite cable lubricant (available from vendors)...excellent results!
