Old 03-27-2024, 06:45 PM   #1
Nicobgoertz
Default Distributor clamp bolt causing no spark??
So I've been chasing a no-spark condition on my '53 8ba-ish flathead, and I noticed the ignition system works fine it the distributor bolt is either absent of loose. but if i tighten it my spark disappears. any ideas what could possibly cause this?
Nicobgoertz is offline   Reply With Quote
Old 03-27-2024, 07:05 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: Distributor clamp bolt causing no spark??
Check the wire underneath the breaker plate. They get old and frayed causing shorts.
Ken/Alabama is offline   Reply With Quote
Old 03-27-2024, 07:32 PM   #3
Nicobgoertz
is that the plate the points are mounted on
Old 03-27-2024, 08:36 PM   #4
Ken/Alabama
Yes
