10-26-2020, 10:41 AM | #1 |
Ignition problem
Number 1 not firing when running.Changed plug. Changed coil. Coil sends spark not running engine. 1 wire was loose at timer at repaired. Appreciate help.
Thanks. |
10-26-2020, 11:14 AM | #2 |
Re: Ignition problem
What are the compression readings?
10-26-2020, 12:15 PM | #3 |
What J Franklin said, maybe stuck valve. You could pull the valve cover off and take a look see. If it is, reach through the spark plug hole and tap it down. Don't pull the head off if you don't need to. There is a shortage of copper head gaskets. If burnt valve, guess no choice, head will need to come off, but be careful and try saving gasket.
10-27-2020, 06:42 PM | #4 |
Yes Ron what J and Red have stated, I bought my T knowing zero @ #1 and 48-50 for the other three.
I pulled the head and did get the exhaust valve to move again but after cleaning the carbon and looking @ the valve seats I had some work to do. New cam, valves, adjustable lifters, timer, wiring ect but... it's running and driving again after a long siesta in a local shed. Just an FYI, the good copper head gaskets are/have been on back order for some time. There now being promised hopefully B4 turkey day Good luck and let us know how you make out. |
10-28-2020, 12:07 AM | #5 |
If it is a stuck valve, try spraying with penetratingly oil before you tap down.
11-02-2020, 07:34 AM | #6 |
11-11-2020, 04:36 PM | #7 |
I read on the other forum yesterday tha Langs and Snyders now have copper gaskets,
John
Welcome each day |
11-12-2020, 07:55 PM | #8 | |
I have developed a slight brake band "chatter" when stopping and will be pulling the hog's head and re-lining my bands over the next few weeks, always something to do to keep'em going |
