Old 07-28-2013, 11:53 AM   #1
Hotrodvideo
Hotrodvideo's Avatar
Default '53 flathead 6v Pertronix conversion
My dad has a '53 wagon, all stock. We want to convert it to Pertronix.
It's still 6v positive ground with a generator.
Will the original coil work? Will Pertronix work ok with the generator?
Has anyone done this swap and can take a pic of the wiring or explain it better because the directions are a little confusing on how to wire it to the coil/ignition.
Thanks!
Hotrodvideo is offline   Reply With Quote
Old 07-28-2013, 01:02 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: '53 flathead 6v Pertronix conversion
I would suggest installing a new set of napa echlin contacts and living happily ever after.
Positive ground six volt PERTRONIXS have some issues with voltage issues, and voltage spikes etc........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 07-28-2013, 01:32 PM   #3
Ford coupe
Is the Napa contacts just a set of ignition points or??Could you explain??
Ford coupe is offline   Reply With Quote
Old 07-28-2013, 01:44 PM   #4
Bruno
I have a '52 F1 - 6 volt - positive grd. Installed a Pertronix Ignitor distributor kit with one of their Flamethrower coils about7 years ago. I love it!!! Installed the coil first and that alone was a big improvement - then put in the Pertronix Ignitor kit - #1283P6 - and it runs like a top!!
Bruno is offline   Reply With Quote
Old 07-28-2013, 04:41 PM   #5
Hotrodvideo
Bruno, can you take a pic of how it's wired to the coil, please? Thanks!!!
Old 07-28-2013, 05:52 PM   #6
BUBBAS IGNITION
Yes buy the echlin heavy duty set with the condenser.
[email protected]
Old 07-29-2013, 08:02 AM   #7
Bruno
Nothing different or special about coil to dist. wiring - wire pos. side of coil to grd. - neg. side to distributor. Then, of course, the coil center wire is connected to the distributor cap center terminal. You may want to call Tony Neisz at Philbin Rebuilt Products - 1-800-867-7301 if you still have questions on Pertronix dist. or coil products.
Old 07-29-2013, 08:40 AM   #8
Mike51Merc
Mike51Merc's Avatar
NO, NO!
This is not correct. With a stock Pos Gnd system the feed wire goes to coil (-) and the coil (+) side goes to the distributor.
With Pertronix, the feed wire goes to the Pertronix Unit, then one wire from Pertronix to coil input (-), and the other side of coil (+) goes to ground.
Mike51Merc is offline   Reply With Quote
Old 07-29-2013, 01:11 PM   #9
jdl
jdl's Avatar
Send a message via ICQ to jdl
This was sent to me from Pertronics, I went with a chevy dist conversion
(points type) from Bubba's
From Pertronics: double click for larger pic
If you have a o.d. trans you need that resistor in the o.d. kickdown wire.
jdl is offline   Reply With Quote
Old 07-29-2013, 08:20 PM   #10
4dFord/SC
4dFord/SC's Avatar
An observation from one who's been there, done that: Point will always get you home, while Pertronix maybe not so much. Just sayin'.
4dFord/SC is offline   Reply With Quote
Old 07-29-2013, 09:46 PM   #11
Bruno
Guess I'm just lucky or something but I've never had any problems with my Pertronix Ignitor set-up - still have the old points, etc. but do not carry them with me in the '52.
My records show I put the Pertronix system in in 2006 - either July or August. Again - just keeps on ticking and taking a licking (like the old Timex???)
Old 07-29-2013, 10:14 PM   #12
296 V8
No luck about it … they make a quality deal.
I use to keep a fleet of 18 ex U haul F 600’s running for a friend of mine.
They all had old Pertronix conversions with who knows how many miles ….. In 6 years I only had one old one fail and iv never had a new one go bad.
The best thing about them is the points screw right back in if need be …. Just keep them in the glove box w condenser and the wire to run to the coil.
296 V8 is offline   Reply With Quote
