Old 05-13-2021, 12:03 PM   #1
tudor 28
Default cross shaft equalizer dropping out
I have an early car. The brake linkage cross member doesn't have the equalizer tabs punched/formed. I've read that from April till August or there about this was how they were made.
Has anybody experienced the equalizer falling out ? It was why they started to put the tabs back in.
tudor 28 is offline   Reply With Quote
Old 05-13-2021, 12:25 PM   #2
d.j. moordigian
d.j. moordigian's Avatar
Default Re: cross shaft equalizer dropping out
No,...my car has the factory fix, the part that your looking for in the want adds.
You need this, it's a BIG DEAL,...IF the "dog bone" falls out you will have NO brakes..!
This was Ford's recall for the A's I believe..
Dudley
d.j. moordigian is offline   Reply With Quote
Old 05-13-2021, 03:13 PM   #3
brito36
Ford had a recall on this problem. It seemed that the center cross member lacked the punched out tabs that originally held the equalizer shafts in position. Ford engineered a bracket that bolted to the center cross member and held everything in place. I believe that the part number was A-2476. I read about this problem and they even had a drawing of the bracket. For the life of me, I just can't remember where I saw it.
brito36 is offline   Reply With Quote
Old 05-13-2021, 04:40 PM   #4
brito36
More information on your brake question can be found in the Septeber 09,1928 1928 Fargo, North Dakota Service Letters. It explains your problem.
