Old 10-02-2016, 09:51 AM   #1
glennpm
glennpm's Avatar
Default Amperage Draw with Ignition on? - Bubba Ignition Question
Hi,
I have one of Bubba's converted crab style distributors on a 59A V8. It is a negative 12 volt ground. Ignition coil resistance measures at 2.6 ohms and has no external resistor.
The 32 is not ready to run yet and am working on the wiring. With the ignition on, I'm getting negative 7-8 amps on my 32 ammeter. Is this a "normal" within range value?
Old 10-02-2016, 10:54 AM   #2
Ross F-1
Ross F-1's Avatar
Default Re: Amperage Draw with Ignition on? - Bubba Ignition Question
Sounds high, but I wouldn't trust a dash gauge to be accurate.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-02-2016, 11:05 AM   #3
Drbrown
Drbrown's Avatar
Check with Bubba, he can best respond .... Russ F-1 right - take a reading at the coil + side with a good test meter. Would amp reading be accurate without engine running ? That internal resistance might be a bit high at 2.8 ? I have two coils, one from Bubba, and each read 1.8 last week. (granted 1.5 or above normal for 12v V8).
Drbrown is offline   Reply With Quote
Old 10-02-2016, 01:30 PM   #4
Dec211975
Calculating the amperage with the numbers provided (12 volts, 2.6 ohms) the amperage should be 4.615
Dec211975 is offline   Reply With Quote
Old 10-02-2016, 02:11 PM   #5
glennpm
glennpm's Avatar
Thanks Guys and Dec211975, I should have checked with Ohms Law like you did. I'm going to recheck my resistance and also see what Bubba may say.
Thanks!
Okay I remeasured and got about 2.3 ohms resistance so ammeter should be about 5 amps considering I measured about 11.7 volts at the ignition switch this morning.
Old 10-02-2016, 03:21 PM   #6
JSeery
JSeery's Avatar
You really need a ballast resistor with that coil value. You are looking for ~3.5 to 4 amps max and if you use the more realistic higher voltage numbers it will be about 4 amps. a charged battery with the engine not running should be around 12.6 to 12.7 volts and with the generator charging the battery it could in in the 14.7 or so range.
12.6V / 2.3 ohms = 5.5A & 14.6V / 2.3 ohms = 6.4A This is way to high and you need a ballast resistor in the circuit, it needs to be sized for the engine running current.
Old 10-02-2016, 04:21 PM   #7
Step-down
Step-down's Avatar
When testing make sure your points are in the open position ..... To evaluate there isn't any other issue your dealing with first ....
"I can't cry as long as I know the Lord has risen "
Step-down is offline   Reply With Quote
Old 10-02-2016, 04:33 PM   #8
glennpm
glennpm's Avatar
Hi Jserry,
Yes, I thought the amperage was too high too. Bubba's FAQ said to just make sure for a V8 that the resistance is greater than 1.5 ohms so I thought I was good until I noticed the high draw this morning on my 1932 dash ammeter. I'll put a ballast resistor in.
Thanks
Old 10-02-2016, 06:08 PM   #9
JSeery
JSeery's Avatar
1.5 would be for like a 6v system OR a 1.5 ohm coil and a 1.5 ohm ballast resistor for a total of 3.0 ohms in the circuit on a 12v system. Without a ballast resistor the coil needs to be in the 3 to 4 ohm range.
Old 10-02-2016, 07:00 PM   #10
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Originally Posted by glennpm View Post
Hi,
Is this electronic conversion or points.???????If electronic the coil that came with the conversion is to be used with the electronic module and shouldnt be tested without the engine running. The module regulates the current with circuits and is a "time " control as well...
If its points then the amps.... is a little ( double _)
high ???
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 10-02-2016, 11:12 PM   #11
Drbrown
Drbrown's Avatar
glennpm .... following-up our pm exchange .... you have a Pentronix module in crab. The coil furnished with that should have internal resistor.
Just communicated with Bubba's. The coil he sold me with my Pentronix was reading 1.8 ohms and he will confirm what a proper reading should be. That should answer your issue about ohm reading for your coil and indicate what amperage your module and coil would be expected to be drawing.
As noted, friday a Pentronix Company Tech advised me their modules are designed to require a minimum of 9 volts and tolerate a maximum of 16 volts. They have been know to survive momentary voltage spikes in excess of 16 (I can attest to that). They are warranted for 30 months from sale for workmanship.
Old 10-03-2016, 06:24 AM   #12
JSeery
JSeery's Avatar
Well, I missed the "converted" in the OP! Little things make a difference!!!!!
