09-29-2016, 01:46 PM | #1 |
39 ford
my 1939 ford front window regulator will not crank out,it moves just a little and then stops any ideas thank you
09-29-2016, 01:58 PM | #2 |
Re: 39 ford
Most likely the regulator is worn out and / or has broken teeth. VERY typical issue.
09-29-2016, 03:56 PM | #3 |
Re: 39 ford
they make a replacement gear for the cast one (if thats the problem)
09-29-2016, 05:41 PM | #4 |
Re: 39 ford
Not that I am aware of.
09-30-2016, 09:28 AM | #5 |
Re: 39 ford
I can't find my photo, been looking since yesterday. On my 39 pu I had the same problem, the knob turned a little but would then jam. The cast gear was bent slightly between the teeth, 2nd and 3rd from closed if I recall, very near fully closed in any case. I used a dremel and about a 1/16" rotary file to provide a little clearance between the football shaped teeth and it now works great. I had to take the regulator apart for access. When I rebent the tabs that hold it together a couple broke off as expected so I tacked them with my mig. I had considered trying to straighten the gear but thought it too likely I'd break the gear and there is more disassembly required. If I can find the photo I'll post it.
This thread has a copy of the photo of my regulator, funny that I can't find it anywhere else... http://www.fordbarn.com/forum/showth...73#post1351373 |
09-30-2016, 10:55 AM | #6 | |
Re: 39 ford
09-30-2016, 06:57 PM | #7 |
Re: 39 ford
I have the same problem with my 39 pickup. How did you get to the regulator if the window wouldn't open? Those screws are really buried.
09-30-2016, 08:17 PM | #8 |
Re: 39 ford
There is a guy on ebay that casts new gears from aluminum he goes by chevi-shop he is from Milledgeville, IL I believe. He currently does not have any listed. I bought several from him and would be willing to help some one out if they need one.
10-01-2016, 06:25 AM | #9 |
Re: 39 ford
thanks
