Old 02-03-2016, 05:43 AM   #1
fords
Default Engine Removal
I read the past post referencing engine removal. Know one mentioned using "Lifting Hooks" as shown in the Model T Ford Service Book. I do not have lifting hooks -but THINK lifting straps would work as well. I am sure I would have to remove the intake and exhaust manifolds not to damage them. The picture in the book sure looked simple. Any thoughts? Thanks Guys
fords is offline   Reply With Quote
Old 02-03-2016, 09:36 AM   #2
Jeff P. / MN
Jeff P. / MN's Avatar
Default Re: Engine Removal
The parts vendors sell a device that screws into the #3 spark plug hole and one can hook onto that and lift the eng/trans out. Seems to balance pretty well.
Jeff P./MN
1913 Model T Runabout
1926 Model T Sport Touring
1948 Chrysler New Yorker
Jeff P. / MN is offline   Reply With Quote
Old 02-03-2016, 10:25 AM   #3
fords
Yes that is correct. I have head off and found issue for rebuild and didn't want to re-install head. But I see my mistake - thinking I could use strap in same area as LIFT HOOKS. I think having LIFT HOOKS would be cool to add to the other things on the wall. Maybe I could find some - In meantime I will look at other ways to lift engine out. Thanks
Old 02-06-2016, 05:41 AM   #4
Sundiesel
Here's a shot of my Speedster engine with a home made lifting hook installed.
Its made from the base of an old pull apart spark plug with a suitable ring welded to it.
Cheers,
Rob
Sundiesel is offline   Reply With Quote
Old 02-09-2016, 12:36 AM   #5
Steve Jelf
Steve Jelf's Avatar
I dislike the idea of putting all that weight on one spark plug hole. I use a chain bolted to two head bolt holes. You can do it with the head removed, or leave it on and use longer bolts.
Steve Jelf is offline   Reply With Quote
