Old 04-03-2018, 05:55 PM   #1
Nelson C
Default 1931 S/W Fordor Sedan Rear Crossmember
Should a 1931 S/W Fordor Sedan have a metal hump over the Rear Crossmember/spring as part of the floor? It would be under the rear seat cushion.
Thank you for your replies.
Nelson C is offline   Reply With Quote
Old 04-03-2018, 07:29 PM   #2
Don Turley
Don Turley's Avatar
Default Re: 1931 S/W Fordor Sedan Rear Crossmember
No. It was made of a canvas like fabric material, held in place with some thin metal strips and screws.
Don Turley is offline   Reply With Quote
Old 04-04-2018, 05:55 AM   #3
Ed Saniewski
Ed Saniewski's Avatar
Mine was made from a matching scrap of the original seat upholstery.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
http://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 04-04-2018, 07:32 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
SO, thet's where that COLD draft comes from!! Helps air out backseat farting.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-04-2018, 07:43 AM   #5
Dave in MN
Dave in MN's Avatar
I just replaced one and took the stitches out of the original to provide a pattern for making the new. The original material was heavy canvas on the bottom side with a layer of upholstery material (I think seat cover...it had a "pin stripe" pattern). The two layers were held together with a thin layer of tar or black adhesive. The adhesive or tar was so thin it looked as if it had been sprayed on one of the surfaces.
Held in place with thin metal strips sewn into the cover. Short "wood screws" through the thin metal strips and into the metal floor pan secured the assembly.
I made mine from two layers of heavy canvas and then sealed the canvas with a melted mixture of 75% bees wax and 25% paraffin wax.
Good Day!
Dave in MN is offline   Reply With Quote
Old 04-04-2018, 09:06 AM   #6
burner31
burner31's Avatar
Made mine from roof material I found buried under all the trash in the back seat area.
There was no cover when I got the car.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 04-04-2018, 04:32 PM   #7
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
This is Original
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 04-04-2018, 05:40 PM   #8
160B
160B's Avatar
Here are two photos of the original spring cover on my 1931 160B
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 04-04-2018, 10:17 PM   #9
duke36
My late '31 is metal attached with similar screws,perhaps aftermarket. Had an early 160B with fabric like the others posted.
duke36 is offline   Reply With Quote
Old 04-04-2018, 10:54 PM   #10
Roadster62
Roadster62's Avatar
I've got to find mine, fairly sure it is metal. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 04-05-2018, 01:09 PM   #11
Nelson C
Thank you all for the replies. Based on your replies, I found that Bratton's Antique Auto Parts sells a Rear Floor Pan Spring Hump Cover (made from roof material) p/n 35970 and Rear Floor Pan Spring Hump Straps (metal) p/n 35980 for the 1931 Town Sedan. Thanks again.
Old 04-05-2018, 01:18 PM   #12
burner31
burner31's Avatar
Made my own straps too, used scrap metal that I had sitting around.
cost for me to install the spring cover $0.00.
Roof material - free
Straps - free
Screws - free
I don't count my labor because I like working on it so much.
Keith
Shawnee OK
'31 SW 160-B
Old 04-05-2018, 06:31 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Straps - free
Screws - free
Can't count your own labor, because who would you collect from?
Old 06-19-2018, 09:25 PM   #14
Doug in NJ
Doug in NJ's Avatar
Is that cover actually made from 5 pieces of fabric stitched together?
I never got around to replacing mine, and last winter the opening provided an entry point for mice, who set up a breeding operation behind the back seat.
So I need to make one and install it ASAP!
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 06-19-2018, 10:06 PM   #15
BILL WILLIAMSON
I once saw some??? car, with a flyweel cover, shaped like that!
Bill Partsjunkieandcollectorofcurbjunk
Old 06-19-2018, 11:16 PM   #16
160B
160B's Avatar
Originally Posted by Doug in NJ View Post
Is that cover actually made from 5 pieces of fabric stitched together?...………………………….Doug
Yes it is made up of 5 pieces, a rear piece, a front piece and three center pieces from the drivers side to the passengers side. I hope this terminology is clear enough.
Old 06-20-2018, 05:30 AM   #17
Ed Saniewski
Is the fabric from the headliner or the seat upholstery?
Old 06-20-2018, 11:25 AM   #18
duke36
ours was outside roofing top material (now available long /short grain vinyl)
Old 06-20-2018, 08:32 PM   #19
Norm M
When I recently pulled the rear seat of my 160B I noticed the rear spring was covered with a small braided rug (I didn't think it was original as it had no "Ford" script on it. I looked for the metal cover like my Tudor has - anyhow found out that Ford made the 160 with a piece of canvas covering the hole heal in place with some 1/2" wide 12 guage straps. I drilled out the rusted screws, used 3/4" wide 1/8" thick flat stock steel and a piece of inner tube.
Norm M is offline   Reply With Quote
Old 06-21-2018, 04:52 AM   #20
Dave Slater
Dave Slater's Avatar
I used an old tyre inner tube as it has the correct curveature. 19" tube by memory. Keeps water out. Dave
Dave Slater is offline   Reply With Quote
