11-29-2016, 10:30 PM | #1 |
Battery Charger Simple Repairs
Batteries should be charged at no more than 10% of their rated amp hours, so if you have an 80 amp hour battery, you should limit the charge rate to 8 or fewer amps. I like these small 4 to 6 amp chargers, and they can be bought for less than $10 at swap meets. Just make sure the meter has numbers, so you can see what's actually happening.
This is one I bought a couple years ago for probably $3 or $4. It was a little beat looking and the charging cord was brittle with several cracks. The power cord was nice and flexible, but had one crack next to the cord lock, so I cut out the 1" where the wires were half broken, then spliced it just inside the case. The clamps were rusty, so for $1.45 I bought a new pair. Four feet cost 60 cents, the cord was 60 cents and the cord lock was 15 cents, so total cost except paint, which I already had, was $2.80, and with care this should last another 50 years. For the charge cord I bought 6 feet of new wire at the surplus store, and a new pair of GB battery clamps at Menards. Two rubber feet were missing and the other two were cracked, so I bought new ones at the surplus store, as well as one missing cord lock for the charge cable. The main part of the case was a mess from someone setting it too close to the battery while it was charging, thus getting acid drops on it, so I sandblasted it and painted it blue. I used a paint brush to clean out the cob webs and thick layer of dust. I labeled the + and - inside the case to be sure the new charge cord didn't get mixed up. I twisted the wires together, soldered them, then slipped heat shrink over them. Also notice the white heat shrink on the charge cord. I did this so the wire won't continue to pull apart after I pulled it apart for 9". I prefer to splice the wires just inside the case, rather than unsolder them at the component, as there is less chance of damaging a component, plus I gain a couple inches of wire length. Notice the two selenium rectifiers riveted to the rear panel. Sometimes they can go bad, mostly from storing the charger in a damp place and letting it get rusty. If they go bad you can use diodes of high enough rating to replace them. If the transformer goes bad it isn't worth buying a new one, but do save the other parts as spares for another charger. I'm not a fan of trickle chargers, but will use these for a light top off charge once in a while over the long winter storage. |
11-29-2016, 10:57 PM | #2 |
Re: Battery Charger Simple Repairs
Excellent.
Very nicely done.
New owner of '28 Tudor Previously owned; '30 Sport Coupe '28 left brake ccPickup '31 SW Town Sedan '28 AA Stake Bed '30 Cabriolet '42 Super Deluxe 4door Sedan "If it don't fit, get a bigger hammer. If it breaks...... ya needed a new one anyway!!" Doing a good job here is like wetting your pants in a dark suit. It gives you a warm feeling, but nobody notices. Never pass up a bathroom Never neglect an erection Never trust a fart |
11-30-2016, 01:21 AM | #3 |
Great write up Tom. An worker gave me a 6v charger from the 40's I am guessing. All the wires are shot, which is no big deal to replace. Is there any way to check and see if the rest is still good?
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
11-30-2016, 01:42 AM | #4 |
Nice one Tom. I get huge pleasure from resurrecting old tools and appliances (workshop ones not kitchen and household ones !) too.
It's not to save money for me either, but to bring back to life some quality item made yesteryear with the technology that existed then. It can get quite involved because some of my favourite things are old machine tools from the 1800's up to the 1960's. My favourite lathe is a Seneca Falls tool room lathe from 1898. I do light stuff on it and heavier stuff on my Dean Smith and Grace lathes from the 1960's. Or my Cincinnati Millacron mill from the 60's. I just got given a Kondia Power Mill from 1968, and I am "restoring" this. Inverted commas because I am patching the paintwork otherwise it will be too pristine to actually use. Please keep feeding the restorations Tom. Do other barn members enjoy these as much as I do? SAJ in NZ |
11-30-2016, 01:45 AM | #5 | |
If it has a bad rectifier tube I'd think that could be hard to find and fairly expensive. I'd clean it up and make sure the 120 volt wires are in good condition, then plug it in and measure the DC output voltage. |
11-30-2016, 09:25 AM | #6 |
Mike
11-30-2016, 09:56 AM | #7 |
a nice job by a true professional. WAyne.
11-30-2016, 02:39 PM | #8 |
Great write up! And these days, it's getting harder to find new battery changers with 6 and 12 volt output.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
11-30-2016, 03:13 PM | #9 |
Found a like NEW Ultrasonic Foot Washer, in the dumpster, behind the drug store, with the cord snipped off.
With a new cord & warm water & Tide & PURPLE Aquarium Gravel, it cleans small parts, like a CHAMP !----The GRAVEL tickles my FEET! Bill Clean
11-30-2016, 03:42 PM | #10 |
Tom: Old tubes are available at Antique Electronic Supply, https://www.google.com/search?q=tube...utf-8&oe=utf-8 The go to place for radio restorers.
11-30-2016, 11:38 PM | #11 |
Tom,
Here is what I have-or what is left of it. The company was incorporated in 45 and is now inactive-for whatever that is worth. I am guessing it is from the 50's. Mike
12-01-2016, 02:26 AM | #12 | |
1930 Coupe, that is a nice quality charger you have, and very handy to have one with adjustable output. |
12-01-2016, 06:39 AM | #13 |
Join Date: Dec 2010 Location: FRESNO, CA Posts: 9,550 Re: Battery Charger Simple Repairs Found a like NEW Ultrasonic Foot Washer, in the dumpster, behind the drug store, with the cord snipped off. With a new cord & warm water & Tide & PURPLE Aquarium Gravel, it cleans small parts, like a CHAMP !----The GRAVEL tickles my FEET! Bill Clean nice find Bill! I like to buy used crock pots for about 5. and put vinegar in them and drop a small part in for cleaning............................ |
12-01-2016, 09:28 AM | #14 |
Hi Tom,
Thanks for the input. Yes the cords are shot totally but the clamps are still good! My intention is eventually to buy a darkroom timer and use that in between the charger and the wall. I had not thought about putting an ammeter in the circuit but that is a great idea. Is there a way to test the rectifier with out plugging in a battery? Mike
12-01-2016, 09:50 AM | #15 |
Thanks for this post. Very timely. I have an old one of mine that quit working, but I am not sure how to get it going again. I will send a PM for some advice.
12-01-2016, 09:57 AM | #16 | |
That's a selenium-rectifier charger. Those big squares are cooling fins for the rectifier stack. Selenium rectifiers can degrade over the years, but a good electronics guy can re-fit with a modern rectifier, and return the unit to service. I have a Sears Allstate vertical charger, 6-12-24 volt from the late 1940's with a bad selenium rectifier... will be getting it to an electrical engineer friend for repair this winter. Frank |
12-01-2016, 12:11 PM | #17 |
Tom, you are man after my own heart. You are a man of many talents. I too hate to throw things away when they break and will try to fix them. I picked up a Rayovac Charger years ago at a swap meet in Tucson for $.50 as they said it would not work. Took a chance and was a blown fuse inside. Being an Electronics Technician and had a degree in Electrical Engineering, was not a problem. Now you can hardly repair anything Electronic as they make it difficult to find parts and then everything is surface mounted inside. Still have signal generators and O scope.
12-02-2016, 12:10 AM | #18 | |
12-02-2016, 08:45 AM | #19 |
I have a battery charger that the meter has died in. Do you have a source of new amp meters? Thanks By the way did the Kingston carb. arrive? Jack
12-02-2016, 01:15 PM | #20 | |
I've also been looking for a meter lens, but no luck so far. Two of our good surplus stores have closed this year, so good stuff is now even harder to find. |
