Old 09-14-2022, 11:49 PM   #1
Ruth
Default Valve Spring Compressor
While on a tour a freinds car started running rough. We found that he burned a valve.
What do you guys use or recommend for a valve spring compressor? Thee spring compressor I have doesn't seem to compress the spring far enough so we can get the keeper out. He has modern valves and retainers.
Does the type that the vendors work pretty good? https://www.snydersantiqueauto.com/7...oppingcart.htm
Ruth
Old 09-15-2022, 04:58 AM   #2
Bruce of MN
Bruce of MN's Avatar
Default Re: Valve Spring Compressor
I use a standard OHV type compressor. It looks like this one, but I got it 40+ years ago, so I don't remember the brand https://www.napaonline.com/en/p/SER3...essionRank=12V
This type has been recommended for flathead motors, I got a used one on ebay some time ago, but haven't used it https://www.napaonline.com/en/p/SER3...ressionRank=15
Bruce of MN is offline   Reply With Quote
Old 09-15-2022, 07:26 AM   #3
BTERRY29
BTERRY29's Avatar
I used this yesterday. Easy peasy.
KCHEX 8" Valve Spring Compressor Hand Tool Automotive Engine Compress/Release New https://a.co/iyRhHGt
BTERRY29 is offline   Reply With Quote
Old 09-15-2022, 08:30 AM   #4
nkaminar
nkaminar's Avatar
The antique spring compressors sometimes have to be modified to fit.
Old 09-15-2022, 09:46 AM   #5
katy
katy's Avatar
I like the original Ford style, something like this:
https://www.mikes-afordable.com/product/T6513T.html
Old 09-15-2022, 09:47 AM   #6
BillCNC
BillCNC's Avatar
For my Hillbilly valve job, I went full Hillbilly and made one. If you have access to a welder and some scraps, have at it. Works like a champ.
Parts are zip tied together for storage.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 09-15-2022, 10:29 AM   #7
PC/SR
Concur the OHV type works well on the modern valves and springs. Shop around. You should be able to get on cheaper than shown in the post.
PC/SR is offline   Reply With Quote
Old 09-15-2022, 02:33 PM   #8
amclass
amclass's Avatar
Or go cheap for under $11 ...
https://shop.advanceautoparts.com/p/...r+Hinge+Spring
Advance Auto Parts: Door Hinge Spring Tool, #38384
You're welcome ...
amclass is offline   Reply With Quote
Old 09-15-2022, 03:31 PM   #9
burner31
burner31's Avatar
Same as I use, and it fits in the tool box
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 09-15-2022, 03:58 PM   #10
alexiskai
alexiskai's Avatar
Biggest problem with that one is that you really need a buddy to hold the spring up while you place the keepers. I know you can use grease to make the keepers stick, but I've never been able to do it with one hand while yanking on a lever with the other.
Old 09-15-2022, 04:27 PM   #11
Bruce of MN
Well done!
You're welcome ...
Old 09-15-2022, 04:31 PM   #12
old31
So, i am going to guess that the best tool is the one that bterry showed on #3. Anyone see a problem with that one.
I am interested because i need to use one.
I picked these compressors up at local flea markets. The small one is labeled Sunnen and it says for Model A Ford.
How do these look to you expert valve guys.
Old 09-15-2022, 05:20 PM   #13
amclass
amclass's Avatar
Originally Posted by Bruce of MN View Post
Well done!
And it fits perfect in my travel toolbox in case I need to do a valve job at some remote beach here in Florida ...
Yeah ... you can call me cheap, but honestly, how many times in life do I really need a spring compressor ?
Old 09-15-2022, 05:59 PM   #14
BTERRY29
BTERRY29's Avatar
for me its was super easy. 1 person job, keepers and all.
Old 09-15-2022, 07:00 PM   #15
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Trust me, grease is the word!
Ivan in southeast va. is offline   Reply With Quote
Old 09-15-2022, 07:38 PM   #16
Ruth
Thanks guys. I ordered one of each. I may never need them again so i will donate to our club's tool crib so other members can use them.
Another question, his engine has double lock lifters. Does anyone know what size the adjusters are and where to get the wrenches. They are really thin.
Ruth
Old 09-15-2022, 07:42 PM   #17
Ayers1
Ayers1's Avatar
You're welcome ...
This one works like a charm for me..
Ayers1 is offline   Reply With Quote
Old 09-15-2022, 08:16 PM   #18
David R.
I have one I bought in 70’s when I was doing flat head Willys Jeep engine. Works great on model A. Looks like half of a little scissor jack. One fork slides under keeper and one in between first coils of spring, then tighten a little hand wheel on end.
David R. is offline   Reply With Quote
Old 09-15-2022, 10:58 PM   #19
PC/SR
Ruth--AS I recall the double lock lifter are 7/16 but not so sure I would buy before a measurement. The thin wrenches are found by luck. They are cheaply made and only turn up occasionally. Easiest is to grind down an ordinary wrench.
Old 09-16-2022, 12:30 AM   #20
Ruth
Thanks, That is probably what I will do.
Ruth
