Old 04-16-2022, 11:37 PM   #1
jeepguy1948
Default 90 degree oil filter adapter
I have ordered a oil filter kit from Mike's. I would like to install a 90 degree adapter to change the filter mount from horizontal to vertical. The problem is that the adapter is dang near as expensive as the whole kit it doesn't seem to me that one of them should sell for $135 (approx.). I know that they were installed at the factory on some mustangs and such but I can't find a used one. Any ideas?
jeepguy1948 is offline   Reply With Quote
Old 04-17-2022, 12:05 AM   #2
G Baese
G Baese's Avatar
Default Re: 90 degree oil filter adapter
The 90* oil filter adapter was also used on some trucks and Econoline vans with the 240 cu.inch six- part number C5TE-6884. Try that number while searching.
These have been hard to find for a number of years and even greasy used ones are often $80-125.
Once you dump oil all over your self, front radius rod, garage floor and the engine pans (if you have them) using the horizontal mount and clean up the mess, the price ain't so bad... That's why I gave $75 for one nine years ago. No mess putting a full filter on or taking one off. Sweet!
Good luck,
-gb
G Baese is offline   Reply With Quote
Old 04-17-2022, 01:15 AM   #3
PC/SR
Agree with G Baese. I paid $80 after my first oil change. There were also used on 300 ci straight six. Might try a wrecking yard.
PC/SR is offline   Reply With Quote
Old 04-17-2022, 09:53 AM   #4
Fullraceflathead
Fullraceflathead's Avatar
I've seen them at the junkyard where you pull them off yourself for under 25 but it depends on what junkyards are in your area and pricing
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 04-17-2022, 10:33 AM   #5
PalAl
PalAl's Avatar
Good luck,
-gb
If I can jump in here, I have seen these advertised, same part number but with a letter following the numbers. I think I have seen A & B is that letter significant for the Model A application? Thanks
PalAl is offline   Reply With Quote
Old 04-17-2022, 11:09 AM   #6
brokenspoke
I bought mine on Ebay off a 1961 Ford Van 25.00
brokenspoke is offline   Reply With Quote
Old 04-17-2022, 11:24 AM   #7
old31
The other advantage of the 90 is that you can fill it full of oil before you install it. You can not do that with the straight type.
The last one I bought was about $125.00
C5TE-6884 does not look to me like it is correct.
The correct number is m-6880-a50.
old31 is offline   Reply With Quote
Old 04-17-2022, 02:34 PM   #8
jeepguy1948
So, I gave in and bought a new one $135. I think that's a ridiculous price for it but yes, I see that the value is there and I don't have time to wait, I want to get it installed before I change the oil. Thanks for the help!
Old 04-17-2022, 04:11 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
To answer your question, the "A" type is the older Ford Part like on the picture of my engine. The "B" type is the modern 90° adapter that is anodized blue from Ford Racing. https://www.summitracing.com/parts/f...-b50/make/ford The "A" type is no longer available new.
Both will fit the Model A. One thing to watch out for is some of the adapters for Ford sixes is that they 'lean' toward the front of the engine and may hit the timing gear cover or oil return line. Bye...
"A" type 90° oil filter adapter
Old 04-17-2022, 05:09 PM   #10
old ugly
old ugly's Avatar
i think that adaptor was used on early 1960s ford 6cyl. Econoline because of the tight engine compartment.
maybe a place to start looking for a cheep one..
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 04-17-2022, 05:38 PM   #11
denis4x4
denis4x4's Avatar
Check Speedway or Summit for adapters and remote filter kits
File Type: jpeg FF33D1CA-DD8A-4134-A6FE-C56B1F3EDBF2.jpeg (40.5 KB, 88 views)
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 04-17-2022, 06:45 PM   #12
SAXBY2
Be aware the new B blue ones may come with metric fittings for the filter, wont' fit the
FL1 A's, etc.
SAXBY2 is offline   Reply With Quote
Old 04-17-2022, 10:09 PM   #13
PalAl
PalAl's Avatar
Thank you YB that's just the info I was looking for
Al
Old 04-17-2022, 10:48 PM   #14
old31
Y, that looks like a m-6880-a50, 90 degree.
Old 04-28-2022, 08:52 AM   #15
C1Nelson
What filter fits the B adaptor?
C1Nelson is offline   Reply With Quote
Old 04-28-2022, 09:56 AM   #16
SAXBY2
Motorcraft FL500 or 800 filters
Old 04-28-2022, 10:11 AM   #17
The Master Cylinder
The Master Cylinder's Avatar
Or WIX/NAPA 57502/7502.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 04-28-2022, 11:59 AM   #18
Flathead
Flathead's Avatar
I had one from an old Ford truck, it is now lost in my vast collection of stuff. I do remember that there was a special bolt that fastened it to the engine block, if you find an adapter be sure you have the bolt too.
Flathead is offline   Reply With Quote
Old 04-28-2022, 12:38 PM   #19
old ugly
old ugly's Avatar
my son just pulled this off of a ford six that came out of a 60s econoline. so they are still out there.
old ugly
Old 04-28-2022, 02:36 PM   #20
The Master Cylinder
Check that one closely old ugly. Notice it "leans" toward the front of the engine as Y-Blockhead mentioned in post #9. Notice yours "leans" the opposite way as his does in his picture. Yours will come real close to the timing gear cover.
The Master Cylinder
