08-17-2021, 12:58 PM | #1 |
radiator
I hope this isn't a dumb question but, I'm going to install a aluminum radiator in my 53. My question before I go to far is, does the core support have to come out with it? Thanks for any advice.
08-17-2021, 01:28 PM | #2 |
Re: radiator
No. You shouldn't have to remove the core support if the radiator is correctly manufactured to specifications for your car. Be sure to do lots of research on the aluminum radiator you are buying to make sure it is of excellent quality. For example, check out the specifications of this aluminum radiator and see if it will fit. I don't know anything about Champion and am not endorsing them
https://www.championradiators.com/3-...r-FH-1949-1952 and here https://www.ebay.com/itm/26525055116...IAAOSw9fVhAm4e Last edited by 19Fordy; 08-17-2021 at 01:35 PM. |
08-17-2021, 01:47 PM | #3 |
Re: radiator
It is a Champion and I did measure. The measurements are exact. It just books like the stock radiator is sandwitched behind the support.
08-18-2021, 08:28 AM | #4 |
Re: radiator
Loosen all the bolts that secure the radiator and see if the radiator is removable.
Can you post a few photos showing how radiator is installed? Are the bolts directly accessible or is there a sheet metal covering? Last edited by 19Fordy; 08-18-2021 at 08:37 AM. |
08-18-2021, 10:50 AM | #5 |
Re: radiator
I have used Champion radiators. They were well built and fit perfectly, but with less core than the stock radiator in my '41 coupe, would not keep the beast (284", high compression) cool on hot days at a stoplight, or over 60 on the Interstate.
If your engine is stock, it will probably work fine. |
08-18-2021, 02:53 PM | #6 |
Re: radiator
08-18-2021, 05:21 PM | #7 |
Re: radiator
Another circumstance where a magnesium sacrificial anode might be beneficial.
08-19-2021, 07:57 AM | #8 | |
Re: radiator
09-01-2021, 03:45 PM | #9 |
Re: radiator
Brass radiator core.
Aluminum? Don't waste your money going w/cheap heat dispersion. Thank you. |
09-01-2021, 06:37 PM | #10 |
Re: radiator
I'm a brass guy as well, but there appears to be good reports on the aluminum ones.
09-01-2021, 07:42 PM | #11 |
Re: radiator
09-01-2021, 08:08 PM | #12 |
Re: radiator
I have noticed that just about all the criticism of aluminum radiators comes from people who haven't used them. The guys that have seem to be quite satisfied, for the most part.
09-02-2021, 04:17 PM | #13 |
Re: radiator
Having replaced my engine in 53 Merc this spring, I can tell you the radiator is a real pain to put in and out. Its a tight fit to say the least. You don't have much room for error, so I would compare the two really closely before I tried to install the new one. And no, you don't have to pull the support.
