09-16-2016, 12:18 PM | #1 |
radiator
Are the early flat head radiators split into two separate sections left-right? I want put lower radiator hose drains on. Do I need a drain on each side or will one drain work?
09-16-2016, 12:24 PM | #2 |
Re: radiator
Only the core is split. The tanks are single chamber, so only one drain is needed.
09-16-2016, 12:37 PM | #3 |
Re: radiator
Were all years split cores 32-53 or were the later ones not split?
09-16-2016, 01:22 PM | #4 |
Re: radiator
Hose drains? Do you mean radiator drain?
09-16-2016, 01:53 PM | #5 |
Re: radiator
09-16-2016, 03:47 PM | #6 |
Re: radiator
09-16-2016, 03:52 PM | #7 |
Re: radiator
Rockfla, I think you are correct. Does it have something to do with the radiator on these models sitting lower and the hand crank passing through the core area?
09-17-2016, 10:59 AM | #8 |
Re: radiator
Answer to 39Topless My block drains will not come out and there is no drain in the radiator. If you cut a small section out of the lower radiator hose and install pipe with a petcock you have a lower radiator hose drain.
