Old 05-09-2014, 05:13 AM   #1
kwisor
kwisor's Avatar
Default hinge rivets question
hello all
i have to replace the hinges on my passanger door looking at the venders rivets list i do not see any listed what size rivets do i need or can thay be bolted in, 1930 tudor
kevin wisor
1930 model a tudor
1923 model t roadster p/u
kwisor is offline   Reply With Quote
Old 05-09-2014, 05:47 AM   #2
springerpete
springerpete's Avatar
Default Re: hinge rivets question
not sure about sizes but Big Flats Rivet Co, ( bigflatsrivet.com ) has everything you will need,
springerpete is offline   Reply With Quote
Old 10-16-2015, 09:00 AM   #3
JudyK
JudyK's Avatar
I am doing this to some door for a 30 as well. I was wondering what the final outcome was with your door. Did you locate rivets and use them or did you go to screws and nuts? Very curious to know. Thanks Rick
JudyK is offline   Reply With Quote
Old 10-16-2015, 07:41 PM   #4
pat59
pat59's Avatar
I did mine and got the screws and made plates for the back and drilled and tapped the plates for the screws. I think I used 3/8" plate.
-Pat
pat59 is offline   Reply With Quote
