07-08-2023, 03:34 PM | #1 |
oil pump modification?
I read the thread on the Burtz motor oil pump modifications and am wondering if I need to open the slots on the new oil pump just purchased before I install it in a stock engine. His modifications are for his block and oiling system. Pic enclosed of the slots in my pump. I have access to any machine work needed.pumpopening.jpg
07-08-2023, 05:07 PM | #2 |
Re: oil pump modification?
Yes, you will need to open the outlets up a bit, and also block off the slots at the top of the tube to allow the oil to exit to an external filter, if you plan on using one.
Fank |
07-08-2023, 05:52 PM | #3 |
The oiling system on the Burtz is totally different from a stock Model A.
07-09-2023, 05:49 PM | #4 |
Opened both of the slots with a 1/4 end mill. installing the pan tomorrow.
07-09-2023, 11:54 PM | #5 |
I always open them up to 5/16 or 3/8 even on a stock motor.
07-10-2023, 12:52 AM | #6 |
07-10-2023, 08:19 AM | #7 |
