Old 06-28-2023, 11:34 AM   #1
JimG1127
JimG1127's Avatar
Default Fan Belt replacement
I'm replacing the fan belt on my '29 A. The old one had lots of cracks.
I loosened the generator, Its pushed up against the engine block. I have the new belt over the fan pulley and crank pulley. Its inches away from going over the generator pulley. Any tips? Do I need to get some kind of tool to stretch the belt out so I can get it over the generator pulley?
Thanks. I'm pretty new to the world of As.
JimG1127 is offline   Reply With Quote
Old 06-28-2023, 12:17 PM   #2
jack wingard
Default Re: Fan Belt replacement
you can take the generator pulley off. the shaft is tapered
jack wingard is offline   Reply With Quote
Old 06-28-2023, 12:22 PM   #3
alexiskai
alexiskai's Avatar
Hmm, if the belt is a ways from going over the generator pulley with the generator completely loose, that would seem to me to indicate that you might have the wrong size belt. You should be able to easily remove/install the belt with the generator loose, and specifically you need to then be able to pull the generator some distance from the block and tighten it down while retaining 1/2" - 1" of play in the belt. Something is amiss here.
Old 06-28-2023, 02:46 PM   #4
DJ S
DJ S's Avatar
Agreed.
DJ S is offline   Reply With Quote
Old 06-28-2023, 05:16 PM   #5
marty in Ohio
marty in Ohio's Avatar
What belt did you buy and where did you get it?
Marty
marty in Ohio is offline   Reply With Quote
Old 06-28-2023, 07:49 PM   #6
Mulletwagon
Mulletwagon's Avatar
A good "cogged" belt readily available from your local parts store is a BX40. If it is too small try a BX41 or BX42. This belt works especially well on the smaller pulley of an alternator. Good Luck.
Mulletwagon is offline   Reply With Quote
Old 06-28-2023, 08:49 PM   #7
JimG1127
JimG1127's Avatar
Thanks. I agree it cant be the right belt.
Old 06-28-2023, 08:52 PM   #8
JimG1127
JimG1127's Avatar
I bought the belt fron Synders. Its the only belt they have for the A. Part # A-8620
Old 06-28-2023, 09:01 PM   #9
midgetracer
midgetracer's Avatar
Remove the pulley from the generator... then put the pulley in the belt. The pulley should slip back on the generator or you have the wrong belt.
midgetracer is offline   Reply With Quote
Old 06-28-2023, 09:07 PM   #10
Ramman
Guess it not just me.
https://www.fordbarn.com/forum/showt...highlight=Belt
Ramman is offline   Reply With Quote
Old 06-28-2023, 09:34 PM   #11
JayJay
Kinda sneaky, but I've found that when you try to install the belt sometimes it doesn't get into the crank pulley because it gets caught between the pulley and the cross member. Hard to see, and the effect is that it appears the belt is too short. You have to force it onto the crank pulley.
Also, you might see how loose the "H" bracket is on your alternator. If it's way tight and canted too far outside the belt won't fit. If you loosen the "H" adapter and then use the prop that bolts to the front engine cover you may have some better luck. Then tighten the "H" bracket.
BTW, I use a BX40, the BX42 is too long. I find that the standard non-cogged belt available from the suppliers is too long to use on an alternator.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 06-29-2023, 12:22 PM   #12
JimG1127
JimG1127's Avatar
I have a generator, not an alternator. I did just install a new 2 bladed aluminum fan from Synders which is supposed to be a copy of the original except thats its aluminum.
Possibly my crank pulley is not original. Someone added a metal pointer and a mark on the crank pulley which I assume is to show TDC. Ill remove the generator pulley, place the belt on it and see if I can reconnect the pulley.
Old 06-29-2023, 01:13 PM   #13
Bob C
Have you compared the length of the new belt against the old one?
Old 06-29-2023, 01:59 PM   #14
JimG1127
JimG1127's Avatar
Yea I wish I had done that! It went in the garbage a week ago.
I'm also installed a new leakless water pump and I'm installing a new brassworks radiator. New gooseneck with a water temp sensor + gauge.
Old 06-29-2023, 06:16 PM   #15
Afordman31
Afordman31's Avatar
Pull the bolt that holds the generator on, slip the belt into the pulley, you can then work the bolt back in to mount the generator. Then set the tension, not tight but not loose. To tight causes problems.
Afordman31 is offline   Reply With Quote
Old 07-01-2023, 04:24 PM   #16
Gene F
Gene F's Avatar
When I had a powerhouse generator on my A I had to pull the mounting bolt out of the block, cock the generator slip the belt in the groove of the pully, then put the bolt back in, and then snug things down. If you got your parts from Snyders chances are you have the right parts.
Old 07-08-2023, 07:25 PM   #17
JimG1127
JimG1127's Avatar
Thanks! I've been away. I will try tomorrow.
