01-08-2011, 11:20 AM | #1 |
Cylinder Head Nut Wrench
Over on Vince Falter's site, he shows a Snap-On wrench for tightening the head nuts on Model A-B engines. My local Snap-On dealer can't seem to come up with one. Anyone have a clue as to the Snap-On part #?
http://www.fordgarage.com/pages/snaponheadwrench.htm |
01-08-2011, 11:24 AM | #2 |
Re: Cylinder Head Nut Wrench
I believe its a distributor wrench for newer cars but works for A's. Craftsman also?
01-08-2011, 11:28 AM | #3 |
I've got several "distributor" wrenches (1/2 & 9/16), they are all too small for the Model A head nuts (11/16), and they aren't lined up like the one in Vince's pictures. The Snap-On site only lists the smaller wrenches also
01-08-2011, 11:43 AM | #4 |
You might try using a crow's foot wrench, these should be easily available, or try a specialty machine shop supplier. When I worked at PWA there were several custom made wrenches such as what you're looking for. Take a regular wrench, cut to length needed and weld top of a 3/8 or 1/2" socket to it and presto you're all set.
Paul in CT |
01-08-2011, 11:45 AM | #5 |
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
01-08-2011, 11:48 AM | #6 |
http://www.snydersantiqueauto.com/4326 the snap on number on mine is: S8663B the advantage to this design is that the torque is the same as from a socket on the end of the torque wrench. With a crows foot, the length of the arm is increased, increasing the torque to beyond what is read on the register. |
01-08-2011, 11:54 AM | #7 |
Dont look like you need a $50 snap on wrench to access that nut. ken ct.
01-08-2011, 12:51 PM | #8 |
Mike's has one as well for under $20
http://www.mikes-afordable.com/miva/...gory_Code=1116 |
01-08-2011, 01:22 PM | #9 |
The Snap-on number on mine is S-8666. Like the others said the A-suppliers have a tool. The main thing is that the nut and torque wrench connection are concentric.
01-08-2011, 02:35 PM | #10 |
01-08-2011, 03:57 PM | #11 |
It says on Vinces site that Snap-On no longer makes the wrench.
Bob |
01-08-2011, 03:58 PM | #12 | |
Shouldn't be too hard to make if you can weld..
No time to play my Gibson RB-250 anymore.. Maybe.. One day... |
01-08-2011, 04:34 PM | #13 |
I have a "8663B" on my 11/16".
I also have a "8164", 5/8", with a date code of 1947 Does anybody else have the "B" after the 8663? Dudley |
01-08-2011, 04:57 PM | #14 |
CarlG,
The S-8666 is definitely 11/16" that is what I just used on the head nuts. It is about 11" tall and has a larger offset that the 8663B mentioned above. You probably looked it up on an internet search, which lists the incorrect size as 9/16". |
01-08-2011, 06:31 PM | #15 |
I have a friend that is a mechanic. He will torque bolts without a torque wrench-he goes by feel. I have checked him with a torque wrench and he is right on. He does heads all the time.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. |
01-08-2011, 06:35 PM | #16 | |
Thanks for correcting me. |
01-09-2011, 12:00 AM | #17 |
The post you were looking for was on the James Mason site. I merely cut a 9/16" impact socket in half horizontally and welded about a 6" bolt to the outside surface of each of them to "straddle" the distributor. The "offset" is the same at both end so torque readings are not affected. Works great and in my case at no cost since I used a surplus socket.
01-09-2011, 03:24 AM | #18 |
Necessity is the Mother of invention,way to go George. ken ct.Some people dont need a $50 wrench to remove a nut.
01-09-2011, 04:54 PM | #19 |
Re: Question KenCt
Ken, for years I've been wondering why you type your handle after sentences? Do you type that well? Seems like just extra work. LOL coming from a "hunt and pecker."
