12-07-2012, 10:04 PM | #1 |
1932 ford truck
does anybody know if a 32 pick up has a k member and is it the same as a passenger k member?i was wondering if a guy could put one in a car without alot of issues or if it drops lower and changes the caster of the front end or is all together bigger and wont work at all.
12-07-2012, 10:25 PM | #2 |
Re: 1932 ford truck
So long as its NOT a BB truck the chassis in the pick-up is the same as the passenger car - inc the K-member
12-08-2012, 07:01 AM | #3 |
Re: 1932 ford truck
Also remember the 4 cylinder K member and the V8 are slightly different.
Sorry guys. Useless information. See my follow up post below. Last edited by Richard Wilson; 12-08-2012 at 08:07 PM. Reason: useless information to topic |
12-08-2012, 10:09 AM | #4 |
Re: 1932 ford truck
With respect, only very early passenger car/commercial vehicle chassis frame front cross members were briefly unique between fours and V-8s. While there were many changes to the center cross member early in the '32 model year, at any point in time they were common for the two engine types.
12-08-2012, 01:18 PM | #5 |
Re: 1932 ford truck
12-08-2012, 02:39 PM | #6 |
Re: 1932 ford truck
Paul in CT |
12-08-2012, 04:02 PM | #7 |
Re: 1932 ford truck
whats the difference between the 4cyl and V8 crossmembers?i just wanted to know if a pick up k member is the same as a passenger k member,i have the option of using one in my car but i havnt seen it in person and didnt know if it was the same
12-08-2012, 04:54 PM | #8 | |
Re: 1932 ford truck
Charlie Stephens |
12-08-2012, 08:01 PM | #9 |
Re: 1932 ford truck
Sorry guys. I guess I mis-spoke. I was going from memory and was thinking about what I had read several years ago in the book "How To Build a Traditional A-V8 Ford Hot Rod" by Mike Bishop and Vern Tardel. In fact (I just looked it up) on page 29 they diagram the right leg, which according to them is different between the 4 and the 8. The rest of the k-member appears to be the same. As you have pointed out it would not matter much in a 32 frame.
