05-11-2018, 12:17 PM | #1 |
engine oil
anyone use 15/40 diesel oil or 20/50 engine oil ?
05-11-2018, 12:33 PM | #2 |
Re: engine oil
Hey J,
I've used ROTELLA 15/40 wt oil in my B engines for decades. IMV, it is called/known as 'diesel' oil, because it contains elements that make it suitable, maybe preferable, for diesel engine use. I believe that LOTS of model a owners have found that this is a good lubricant for A/B engines, and therefor use it. |
05-11-2018, 12:46 PM | #3 |
Re: engine oil
We have used Walmart 20w-50 oil along with one 16oz bottle of the blue STP for years. We change oil at 500 miles or one year. Engine has about 20,000 miles on it.
Also use MMO in gas. Engine runs quiet, very little dripping, no smoking, after 500 miles normally down about 3/4 of a quart. |
05-11-2018, 01:27 PM | #4 |
Re: engine oil
I also have used Walmart 20w50 in my model A's for years . Mobil produces it and Walmart sells it under tgheir trademark for less . It works good for me .
05-11-2018, 10:13 PM | #5 |
Re: engine oil
I use whatever brand of oil is on special or has just been on special. I sometimes buy in advance of need. 20/50 comes up fairly often so that's what I use. No dramas. It is light years ahead of what was used in the day and is a detergent oil. I run an oil filter and change at about 2,000 miles or when the gauges say it's time. I have a pressurised centre main bearing and when the oil is losing its "guts", the pressure starts to drop at a standard speed and temperature. As soon as that happens, out it goes. Sometimes, 2,000 miles is about 2 weeks driving, sometimes a year.
05-11-2018, 10:13 PM | #6 |
Re: engine oil
05-12-2018, 05:10 AM | #7 |
Re: engine oil
do any of these oils have zink? im told you need it and modern oils have little to none. anyone know ?
05-12-2018, 05:49 AM | #8 |
Re: engine oil
Rotella 15W 40, the rebuilder told me to always add a bottle of zinc.
05-12-2018, 05:49 AM | #9 |
Re: engine oil
I use ANY Multi-Weight oil, if it LOOKS/SMELLS/FEELS right. "Some" are impressed by TRICKY/COLORFUL labels, also! I go a lot by the "feel", it's GOT to feel REAL SCHLICKERY!
Bill Frictionfree
05-12-2018, 06:08 AM | #10 |
Re: engine oil
Yes.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
05-12-2018, 06:34 AM | #11 | |
Re: engine oil
05-12-2018, 02:53 PM | #12 |
Re: engine oil
Good old Walmart Mobil 1 10/30 synthetic. I use it in most of my cars and lawn tractor I like having one brand to use. That way I don’t have 10 different containers of oils to store. I like this simple!!
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
05-13-2018, 12:06 AM | #13 | |
Re: engine oil
Will it do harm? No Will it get you out on the road more if you use it? Then use it. Will it give you peace of mind when driving? Then use it. Do you need it? No
05-13-2018, 12:13 PM | #14 |
Re: engine oil
ive been using 15-40 synthetic
05-13-2018, 01:22 PM | #15 |
Re: engine oil
I use 20-50 in my worn out POS old dodge pickup. My Model A gets 10w-30 as recommended by the guy that rebuilt my short block. The A uses no oil.
05-14-2018, 05:41 PM | #16 |
Re: engine oil
I hqve used Castoral GTX 20-50 for over35 Years. Change oil between 1500-2000 miles, even though the oil still looks new. Have filter and insert main and rod bearings on 2 of the engines.
The reason I started using Casterol GTX 20-50, there was a article in Motor Trend Magazine that rated oil by the company, based on their quality control; Castrerol GTX was rated # 1. My 3rd A does is not driven much as it was built for show; the engine is stock and only has around 50 miles on it. It also has GTX 20-50 in it. So far, no problems with any of the engines. Ron |
05-15-2018, 04:11 AM | #17 |
Re: engine oil
Tried Walmart 20w50 also and my engine seemed to like it.
