Old 12-16-2022, 02:18 PM   #1
41LjH
41LjH's Avatar
Default 3x2 intake and Holley 94
This 3x2 setup built for the fresh Mercury Flathead engine. The intake has never been installed. Hand selected Holley 94 carbs (7RT) tumbled and trued, extended throttle shafts installed. A CORRECT radius 3.5 power valve in the center carb and the others are plugged. The idle circuits in the outer carbs are not defeated because all you need to do is seat the air mixture screws. At this point you can either set the linkage straight or progressive. Speedway Motors gets over $2000.00 for a similar setup using aftermarket carbs without any extra parts (see photos). Alternator bracket not included..
$1400.00 or near offer takes it all. Including many extra Holly 94 parts. Cash for local pickup , PayPal plus Shipping and handling if I ship.
If you have questions.email your name and phone number and I will call you or call (336) 422-1956 and leave a message. I will call you back. Thanks for looking!
tags: Flathead, Ford, Mercury, Hot Rod, Street Rod.
Tags. Ford, Hotrod, Holley, Streetrod , Ratrod, Flathead Mercury, Flathead Ford
3 pedals, 3 gears, no valve-covers..
Now THAT is a hot rod !!
https://www.youtube.com/watch?v=ZmwwB34vxJE
41LjH is offline   Reply With Quote
