Old 02-06-2014, 12:37 PM   #1
ped58
ped58's Avatar
Default 20 or 30 amp gauge?
My '29 model "A" came with a 30 amp alternator, should I change out the 20 amp gauge that's in the dash now with a 30 amp gauge?....thanks
ped58 is offline   Reply With Quote
Old 02-06-2014, 12:44 PM   #2
jm29henry
jm29henry's Avatar
Default Re: 20 or 30 amp gauge?
I think it sound like a good idea .there is more restance in the 30 amp but put your finger on the one that is installed now if its not hot or to warm to the touch you should be fine i am an electrician so this is. Only my perspective. Hope this helps!!!!!
jm29henry is offline   Reply With Quote
Old 02-06-2014, 12:47 PM   #3
Charlie Stephens
Run a jumper wire across the back of the amp gauge. You may be able to do this at the junction box on the firewall depending upon your wiring. Use a wire heavy enough to carry the load in case the amp gauge fails. Now all you need to do is to remember that you gauge will read a little low.
Charlie Stephens
Old 02-06-2014, 03:54 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
The resistance in the buss bar is the same. The difference is in the do-dangle thingy thet hangs on the needle.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 02-06-2014, 04:50 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
Its not likely or even possible that you would ever see a 30 amp charge with your 30 amp alternator. If it was mine and the present 20 amp ammeter fit the dash and worked, I wouldn't mess with it.
Old 02-06-2014, 06:22 PM   #6
BILL WILLIAMSON
Bro, Swoft,
Luv your common sense approach to stuff, like, "DON'T MESS WITH SUCCESS" or "IT HAS WORKED WELL FOR ME" or "WHY OVERCOMPLICATE SOMETHING SIMPLE or, like Chief would say, "THE EASIEST WAY IS THE BEST WAY, AS LONG AS IT DOES THE JOB PROPERLY" or, "JUST USE A QUALITY OIL & CHANGE THE DANGED STUFF WHIN IT GITS BLACK"!
Bill W.
Old 02-06-2014, 07:35 PM   #7
ped58
ped58's Avatar
Thanks for all the good info. I'll just keep it the way it is.
Old 02-06-2014, 08:10 PM   #8
Purdy Swoft
Originally Posted by BILL WILLIAMSON View Post
Bro, Swoft,
Bill W.
Thanks Bill !!!!!!! Yer brother Purdy
Old 02-06-2014, 09:22 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, leave it alone.
Remember, the amp gauge doesn't measure the alternator output.
It measures the charge going into the battery or flowing from the battery.
Old 02-06-2014, 10:27 PM   #10
BILL WILLIAMSON
I have 2 really old Snap-On induction ammeters that you just lay on a wire or the battery cable. They're a really handy device. Wonder if Harbor Freight has them?? Bill W.
