Old 03-18-2024, 12:10 PM   #1
Robchev75
Default Old ford mount
Looking to see if anyone can help me out with this mount ? Is pretty clear the part number , it’s in a custom application but I need new mounts the number , on the mount is KC-6038-A and then under those letters and numbers there -AW 6 with the ford logo , any help identifying the application for this mount so I can replace them would be greatly appreciated.
Robchev75 is offline   Reply With Quote
Old 03-18-2024, 12:18 PM   #2
Ggmac
Default Re: Old ford mount
Mount for what ?
Ggmac is offline   Reply With Quote
Old 03-18-2024, 01:34 PM   #3
Bob C
The 6038 group is an engine mount.
Bob C is online now   Reply With Quote
Old 03-18-2024, 07:02 PM   #4
Robchev75
Originally Posted by Ggmac View Post
Mount for what ?
It’s a motor mount
Old 03-21-2024, 11:16 AM   #5
Als48
Summit Racing has the Bob Drake motor mount cushions in stock. 78-6038-K is what they list them as.
Al H
Als48 is offline   Reply With Quote
Old 03-21-2024, 11:37 AM   #6
Bob C
Can you post a picture of the KC-6038-A, maybe we can
identify it.
Old 03-21-2024, 02:11 PM   #7
rotorwrench
rotorwrench's Avatar
Since 6038 was a basic number then different prefix or suffix can designate a design change. A photo, a good illustration, or knowing what it fit would be the only way to identify which of many it might be. It may be aftermarket or it may be something else. Most aftermarket parts suppliers had their own numbering system. KC is not a common prefix for a biscuit or dougnut type mount. The C by itself has been a prefix for commercial vehicles or pickups but the K is not a common Ford prefix.
The Fords of the flathead V8 era used at least three different types. There was early and late Ford types. The types used in Mercury and Lincoln cars from 1949 thru 1951 were different. They were used again in the Y-block era for 6-cylinder applications. These are all biscuit types. The 49 up Ford and early 1949 Mercury types changed and were not biscuit types. Pickups has biscuit types that were the more common late Ford type till 1953 for V8s. The Ford 6-cylinder equipped cars and trucks with G & H series engines had different mounts altogether.
My question to the OP is what is it going to be used on such as the type of frame or engine? Type of water pump on early and late flathead V8 engines is also a concern.
