12-08-2016, 07:15 PM | #21 |
Re: Because I feel bad about hijacking the 2 blade thread
Basically the only car and temps you should be worried about are YOURS. As long as you're not losing water and/or boiling over and under about 190 consistently you're GOOD. Most people with a temp gauge use the upper neck with tapped boss. Motometers are not reliable. BEST method to ck temp is with a point and shoot thermometer. JMO and FWIW.
Paul in CT |
12-08-2016, 07:23 PM | #22 |
Thanks Paul, I have gathered that from the responses I have received.
I do have that outlet snout with my temp gauge sending unit attached and a hand held point and shoot thermometer.
New owner of '28 Tudor Previously owned; '30 Sport Coupe '28 left brake ccPickup '31 SW Town Sedan '28 AA Stake Bed '30 Cabriolet '42 Super Deluxe 4door Sedan "If it don't fit, get a bigger hammer. If it breaks...... ya needed a new one anyway!!" Doing a good job here is like wetting your pants in a dark suit. It gives you a warm feeling, but nobody notices. Never pass up a bathroom Never neglect an erection Never trust a fart |
12-09-2016, 11:14 AM | #23 |
12-09-2016, 11:20 AM | #24 |
12-09-2016, 11:36 AM | #25 |
I GET IT!!!! haha
What is that? impalla or malibu? All look the same nowadays...
1929 Model AA - Need long splash aprons! |
12-09-2016, 11:36 AM | #26 | |
If my postings bother you , ill try and post more Last edited by Mitch//pa; 12-09-2016 at 08:30 PM. |
12-09-2016, 06:41 PM | #27 |
i once asked a man what time it was>
he told me how to build a watch |
12-10-2016, 09:14 AM | #28 |
I have an early 28 sport coupe, 300 miles on a rebuilt engine, rexaco repop guage mounted in upper rad hose, car runs 190 at 45mph, completely stock gearing, stock 2 blade fan, and ignition timing checked with a timing light. Temp climbs to 200 plus climbing a steep 2 mile hill. She's running cooler and cooler as the miles pile on.
Sent from my iPhone using Tapatalk |
12-10-2016, 11:34 AM | #29 |
12-10-2016, 12:53 PM | #30 | |
https://fordbarn.com/forum/showthread.php?t=206917 Last edited by Mitch//pa; 12-10-2016 at 01:15 PM. |
12-10-2016, 03:30 PM | #31 | |
Was that really necessary? " (sarcastic)" 10,000 posts does not make anybody an expert and does not give them the right to slam other members. You have done that more than once in this thread alone. Maybe it is time you were reported? My request for a water pump photo was to "denis4x4" and not you. Butt out. Last edited by Cool Hand Lurker; 12-10-2016 at 08:57 PM. |
12-10-2016, 03:54 PM | #32 |
Dennis (with two "n's") this is a 32-36 ford V8 pump. Finally had to replace it this year and ended up hogging out the adapter so that the impeller would spin freely. Chinese!!!
No restorable Model A's were harmed in the building of this truck! |
12-10-2016, 03:57 PM | #33 |
If you were looking for a private response it would be best to PM the individual, as posting it to a public forum its open game... (ROLLEYES) not sarcastic
12-10-2016, 05:38 PM | #34 |
Denis, Is there an advantage to running a V-8 water pump? Just curious, from a third Dennis.
12-10-2016, 06:40 PM | #35 |
i did not know 1000 posts entitled false accusations
'31 180A |
12-10-2016, 08:47 PM | #36 |
Thank you. I am working on a modification to the stock Model A water pump to make it easier to remove with the radiator in place. Your method of locating the temp sender is a good idea. I was wondering how you handled the hose being so close to the radiator in a stock Model A, but I see that you had the freedom to relocate the radiator forward. It all gives me some ideas though. Thanks again.
12-10-2016, 08:54 PM | #37 |
12-10-2016, 09:42 PM | #38 |
use coolant then you can smell it when its hitting the ground. I dont see any cars with fan shrouds that would drop temp. if your car is overheating you probably have problems to be addressed.
12-10-2016, 11:16 PM | #39 |
Basically it doesn't leak like an A pump! Too, it's easier to R&R.
12-11-2016, 04:08 AM | #40 |
[QUOTE=Cool Hand Lurker;1397492]Was that really necessary? " (sarcastic)"
10,000 posts does not make anybody an expert and does not give them the right to slam other members. You have done that more than once in this thread alone. Maybe it is time you were reported? My request for a water pump photo was to "denis4x4" and not you. Butt out.[/QUOTE] PM sent! Wayne |
