12-07-2016, 09:12 PM | #1 |
Headlight Bulbs
Having read and not wanting to jump into the thread "Hydro dipping headlight reflectors?" I have a question about the bulbs of the head lights.
I presently have the reflectors sold by Brattons that a lot of people have raved about. QUESTION? When installing the bulbs does the bigger/longer filament go to the top or bottom? |
12-07-2016, 09:42 PM | #2 |
Re: Headlight Bulbs
The upper is the dim, as it directs the light more downward. Dim should be a finer filament and a bit longer.
12-07-2016, 09:45 PM | #3 |
Re: Headlight Bulbs
Strangely enough I would have thought just the opposite.
The LARGE filament on the top and being the HIGH beam. Thanks for the info Tom and I will change my tomorrow. |
12-07-2016, 10:52 PM | #4 |
Re: Headlight Bulbs
can we have another opinion? It has previously been stated different. Wayne
12-08-2016, 12:04 AM | #5 |
Re: Headlight Bulbs
Yup Tom is right, think of the filament on one end of a teeter totter and the lens on the other with an invisible pivot point in between - filament moves down light goes up, filament goes up light goes down.
1929 Model AA - Need long splash aprons! |
12-08-2016, 01:04 PM | #6 |
Re: Headlight Bulbs
Ken
Style beats speed any day, and with a lot fewer tickets. |
12-08-2016, 07:37 PM | #7 |
Re: Headlight Bulbs
I have at least a couple old bulbs that have the TOP marked base from the factory.
12-08-2016, 09:10 PM | #8 |
Re: Headlight Bulbs
The original 1110 bulbs 32-32 CP bulbs have two identical filaments (both are pointed), one is mounted slightly off-center (Low Beam). The off-center filament should be towards the top of the reflector when locked in place. As mentioned, these bulbs have the word "TOP" rubber-stamped on the lamp shell.
If you're using the modern 50-32 CP bulb, the thin flat filament goes on top, and heavier, pointed filament should be on bottom, at center of reflector. I went back to using the 1110 32-32 CP bulbs, as they seem to last longer. |
12-08-2016, 11:40 PM | #9 |
Re: Headlight Bulbs
12-09-2016, 07:33 PM | #10 |
Re: Headlight Bulbs
I have avoided the bulb filament question by replacing my headlamps with acetylene headlights from a 1909 Brush.
