Old 10-27-2016, 07:23 AM   #21
mshmodela
mshmodela's Avatar
Default Re: First Model A 1930
Nice car and wow you've been busy....happy to see you elected to do a proper job and remove that blue... Keep the photos comming.,
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 10-27-2016, 09:02 AM   #22
32 chevy vett
32 chevy vett's Avatar
Thats O.K. Mike. We are both learning about Model A's. I've got a lot to learn.
32 chevy vett is offline   Reply With Quote
Old 10-30-2016, 07:53 PM   #23
32 chevy vett
Brushed on some KBS RUST SEAL today.
Old 11-02-2016, 09:33 AM   #24
L head fan
Looking great Don! Keep up the good work.
L head fan is offline   Reply With Quote
Old 11-04-2016, 07:43 PM   #25
32 chevy vett
Still at it the header was bad on the ends. So I removed it and replaced it. Painted all parts I had sandblasted epoxy on the top and KBS on the bottom.
Old 11-08-2016, 05:58 PM   #26
32 chevy vett
Done sandblasting monday pulled the engine and pressure washed today.
Old 11-08-2016, 06:27 PM   #27
Stew Masche
Stew Masche's Avatar
You're a real 'go-getter'! At this rate, you should be able to put a bow on it, all finished, and park it under the tree for Christmas!!
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 11-08-2016, 07:48 PM   #28
Tom Wesenberg
Tom Wesenberg's Avatar
You're going to have to slow down. You're making the rest of us look bad.
Pretend you work for the highway department.
Old 11-09-2016, 08:35 AM   #29
32 chevy vett
No I have two things against me the weather and my body. I have been lucky with the weather but at 74 the mine says yes and the body says NO! 9 hours of nonstop sandblasting to beat the weather took two days to recoup.
Old 11-11-2016, 03:01 PM   #30
GT Mustang
Your doing a super job, as usual Don!! Looks great Cant wait to see it next week
GT Mustang is offline   Reply With Quote
Old 11-13-2016, 09:34 PM   #31
32 chevy vett
Finished up the last of the big parts of the sand blasting. And got a coat of epoxy primer on them.
I guess I was going so fast I forgot to take photos of the last of the epoxy prime job!
Old 11-13-2016, 09:55 PM   #32
32 chevy vett
Got two coats of filler primer on most of the parts today. Still have to do the body.
Coat the frame with KBS. Cleaned up the engine and the man that gave me the car stopped in so I put him to work and we put the engine back in.
Old 11-17-2016, 09:31 AM   #33
petcar
Heheh! I had to laugh when I read your post. I have a 95 Corvette convertible, and a 1931 160-C Model A ( Murray body ). I'll walk into the garage to grab a car to go somewhere. I'll walk to the Vette, then look over at the Model A... and sure enough I will end up taking the Model A out. (( As long as it's not raining!!! )). I went through a few A's before I found my true love, But as they saying goes...You never forget your First!
petcar is offline   Reply With Quote
Old 11-18-2016, 11:52 AM   #34
Brace Bailey
Brace Bailey's Avatar
I really like your Vette Parts hanger.... I have one too....
Brace Bailey is offline   Reply With Quote
Old 11-18-2016, 07:43 PM   #35
32 chevy vett
i have to thank the good lord I got good weather long enough to get every thing in filler primer. I Put the snow blower on my 420 John Deere I think my luck is running out fast.
Old 11-19-2016, 05:10 PM   #36
32 chevy vett
I have always had problems trying to work on front fenders. So today I said to my self.
Self I said we have to do some thing about this problem. I had rolling jig I used to work on Model T bodys. With a Model T frame C clamped to it. I removed the frame. Made two t bars and a
1 1\2"Sq. tube cut to fit the under inside of the fender drilled and tapped it through the hole for the running board. C clamped to my old jig.When I'am done doing one fender I unclamp 3 clamps reverse the T frames and do the other fender
Old 11-24-2016, 04:52 PM   #37
32 chevy vett
Worked on taking the head off 4 to 5 hours on wed.used a penetrating oil made with a
50/50 mix of acetone and auto trans fluid let it set all nite went out this morning got it loss.
Worked on for 3 more hours before I got it off. I could only get 2 studs out of the block.
The last one to work on it must have tighten the studs into the block real tight with no never seize.
Old 12-02-2016, 04:29 PM   #38
L head fan
I know you'll get them out Don...persistence pays off.
Glad you're feeling better, and back at it.
Old 12-08-2016, 08:53 PM   #39
32 chevy vett
Lapped in all the valves put the head back on pulled the pan good thing. Some one left a rag in the the pan it laid flat and some how was not picked up by a rod cap. Cleaned up engine
new gaskets and a paint job. Went over the frame and running gear looking for spots I missed and lite spots.
Old 12-08-2016, 10:35 PM   #40
old car guy
Your doing a great job love the t in the rear of the frame pictures . Does it run as good as it looks. At the rate your going you be finished by the middle of January. Keep all of the pictures of your journey coming .
old car guy
old car guy is offline   Reply With Quote
