Old 04-30-2024, 05:31 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default 54 Mercury-box on firewall ID
Can anyone advise what this electrical box is on the firewall of my 54 Mercury.?? Seems like A HEAVY gauge wire running under the dash to the ignition switch I think..
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 04-30-2024, 05:40 PM   #2
cadillac512
cadillac512's Avatar
Default Re: 54 Mercury-box on firewall ID
If you have overdrive, is it the OD relay?
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 04-30-2024, 05:45 PM   #3
Bob from Northport
I do have an overdrive on the car. Have not tried it yet since I've had the car.
Bob from Northport
Northport, Michigan
Old 04-30-2024, 11:20 PM   #4
miker98038
miker98038's Avatar
Big wire to the relay to actuate the pull in coil on the solenoid. Then it switches over to a holding coil internally and the load goes down. I dont have a manual where I’m at, but I thought they were fed right off the battery (on my bird via the starter solenoid) and the coil circuit was thru the ignition. ?
Have you driven those overdrives before?
miker98038 is offline   Reply With Quote
Old 05-01-2024, 12:08 AM   #5
KULTULZ
KULTULZ's Avatar
Arrow Re: 54 Mercury-box on firewall ID
https://www.oldcarmanualproject.com/...age_01_jpg.htm
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL -
KULTULZ is offline   Reply With Quote
Old 05-17-2024, 06:51 PM   #6
Oldgearz
That sure looks like the OD relay box as mentioned above. Fuse tips it off. If it has 4 wire connections, I'd bet on it.
Oldgearz is offline   Reply With Quote
