Old 06-26-2015, 03:35 PM   #1
31ma
Default Want to change steering wheel of my 1931
I would like to change the original steering wheel of my 1931 ford mode a for any other original steering wheel but more modern style like 1950s.
But the thing is that I reaaly dont know what steering wheel can fit without making any change. Someone here that knows what wheel can I use if you can let me know the model and year of a car that uses that steering wheel that I can use so I can look for one. Thanks.
31ma is offline   Reply With Quote
Old 06-26-2015, 04:36 PM   #2
john in illinois
john in illinois's Avatar
Default Re: Want to change steering wheel of my 1931
I think model A wheels are unique. All later Ford wheels have a different taper shaft.
John
john in illinois is offline   Reply With Quote
Old 06-26-2015, 04:42 PM   #3
C26Pinelake
I agree with John. It would be a major engineering exercise ! Wayne
C26Pinelake is offline   Reply With Quote
Old 06-26-2015, 06:10 PM   #4
Mitch//pa
do you still want to use the original horn rod set up??
Old 06-26-2015, 09:46 PM   #5
burner31
burner31's Avatar
Can you post a picture of the wheel you want to remove/replace.
If its in decent shape I may be interested in it.
Mine is OK, but really shows it's age.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 06-26-2015, 11:32 PM   #6
C26Pinelake
What is the reason for change ? Wayne
Old 06-26-2015, 11:58 PM   #7
waxhead
waxhead's Avatar
As stated above, the Model A steering column taper is different (bigger) to the later model Fords.
I have just fitted a Ford Banjo steering wheel to my Model A steering column, and am still using the original horn rod set-up.
I did a small write up on the HAMB on what I did. I modified the Banjo steering wheel hub taper, so I can easily install the original Model A steering wheel if want to.
http://www.jalopyjournal.com/forum/t...#post-10961903
waxhead is offline   Reply With Quote
Old 06-27-2015, 05:45 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
My 31 had a later 30's banjo steering wheel on it when I bought the car. I removed it and installed the correct wheel.
How late do you want to install, and what about the light switch?
Old 06-27-2015, 08:41 AM   #9
mshmodela
mshmodela's Avatar
Love my 31' wheel, I'd put it on my modern cars if iI could lots of hand room...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 06-27-2015, 12:11 PM   #10
Idaho Brett
Idaho Brett's Avatar
I don't know if the 50's style steering wheels use the '60s and '70s 3-hole mounting methods or not, but this adapter might work for you.
http://www.speedwaymotors.com/1928-1...-Hub,3307.html
Idaho Brett is offline   Reply With Quote
Old 06-27-2015, 01:40 PM   #11
Mitch//pa
nice adapter,
there is usually something available to make most conversions easily doable
Old 06-27-2015, 07:29 PM   #12
waxhead
waxhead's Avatar
I would be interested to see if that hub adapter works, given that the steering column taper is different between Model A's and later Fords, yet it states that it is good for 1928-1948 Fords.
It does give the dimensions of the taper in the adapter, so I would check that against your column taper and confirm that it is suitable. I am not near home at the moment, so I cannot confirm if these dimensions would be suitable.
Old 06-27-2015, 08:28 PM   #13
Idaho Brett
Yeah, I don't know the dimensions of the taper on the Model A steering column, either. I was just going by the years that it said it would fit. And the picture showed a slot for the "woodruff key".
