Old 08-12-2018, 07:32 PM   #1
fordrelic
Default What year B motor
Can anyone tell me when this motor was made?
I will attach a picture with serial.
Thanks!
fordrelic
fordrelic is offline   Reply With Quote
Old 08-13-2018, 12:01 AM   #2
Chris Haynes
Chris Haynes's Avatar
Default Re: What year B motor
The first thing is that B engines didn't have numbers. There should be a date code on the block under the front of the valve cover.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 08-13-2018, 12:51 AM   #3
Randy in ca
Randy in ca's Avatar
I assume your picture is of the number stamped in the usual location on top of the flywheel housing. Using Vince Falter's site, I get September 1932. Link below for you to confirm.
http://www.fordgarage.com/pages/ABenginenumbers.htm
Randy in ca is offline   Reply With Quote
Old 08-13-2018, 07:13 AM   #4
fordrelic
Randy in ca,
Yes it is number from flywheel housing. Thanks for the information.
Old 08-13-2018, 10:48 AM   #5
Jim Brierley
The real early B's had a boss cast on the left side of the block, towards the front that was intended to mount part of the proposed vacuum assist for the clutch. Early firewalls had a ledge to mount another part of the system. This system never reached production.
Jim Brierley is offline   Reply With Quote
