Old 08-06-2018, 10:26 PM   #1
noyo55
Default Model B Carb
I have decided to install a B carb on the B engine in my 30 Coupe. I dredged up a B intake, from all the stuff in the back of my shed. What am I looking for, part numbers for a Zenith and what aftermarket carbs were made for it? Thanks.
noyo55 is offline   Reply With Quote
Old 08-06-2018, 10:38 PM   #2
Terry, NJ
Terry, NJ's Avatar
Default Re: Model B Carb
I think it is wise decision! The "B" has it all over the "A" for at least three reasons. 1) The float is hinged sideway, not fore and aft as an "A" carb. Sudden stops don't make it stall.
2) The "B" carb has an accelerator jet tube that helps with acceleration.
3) The "B" carb has a much larger bore (1.250) and can process more air. If you go to my album "Miscellaneous stuff" I took some pics for a side by side comparison.
Terry
Terry, NJ is offline   Reply With Quote
Old 08-09-2018, 05:46 PM   #3
noyo55
Thanks Terry I did look at the carbs. Good to see what I'm looking for. Tom
Old 08-09-2018, 07:24 PM   #4
Gene F
Gene F's Avatar
I went with it due to a bigger bore, and more air too.
Gene F is offline   Reply With Quote
Old 08-09-2018, 10:34 PM   #5
lake_harley
I'm a complete noobie to Model A's, but I thought that linkages line up better if a B carb is used with an A manifold. If I recall correctly, it has something to do with the flange on a B manifold being angled slightly that then puts the carb at an angle. To gain the performance benefit, I also understand that the A manifold needs to be bored to match the larger B carb. I also have a B carb to put on an A and would like to know if my understanding and/or information is correct, or all messed up.
Lynn
lake_harley is offline   Reply With Quote
Old 08-10-2018, 04:22 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Lynn, you are correct.
Old 08-10-2018, 11:21 AM   #7
Terry, NJ
Terry, NJ's Avatar
Lynn, I've gone with the bored out A manifold (1.250 VS 1.125) and I have had no problems, No "Chinese" screws. In the shops, a "Chinese" screw or bolt was one where the shank was smaller than the thread size to accommodate misaligned hole. My linkage seems to work OK. If you want to bore out your manifold, you'll need a Bridgeport or a large heavy Drill press with a large angle plate, and a 4" LG locating pin approximately 1.100 dia. Write me for details.
Terry
Lynn
Old 08-10-2018, 12:54 PM   #8
denniskliesen
denniskliesen's Avatar
Most people bore an A manifold, I elected to weld up the flange on my B manifold and drill the holes the same angle as an A. My GAV works perfect as well the rest of the carb linkage.
denniskliesen is offline   Reply With Quote
Old 08-10-2018, 02:25 PM   #9
Purdy Swoft
Purdy Swoft's Avatar
I also cut the flange off the model B intake and brazed it back on at the model A angle . The model B intake is a better choice to get the full power of the B carb . Boring out or reaming out the model A manifold runner gives improvement but the runners that connect to the engine are also larger on the model B intake . The top of the model B intake is flat and had an effect on distribution of the mix to the intake valves. If the intake ports are enlarged on the model A block to model B size and used with the B intake manifold you should get nearly a three horsepower increase with the B carb . Another consideration is that two different inside diameter venturis were used with the model B style carburetors . The smaller venturi was used when the B carb was sold as a replacemnent for the model A carburetor after the model A Zenith carbs were discontinued . Both venturis are available but if you want the full effect you will need the larger model B venturi .
Old 08-10-2018, 03:08 PM   #10
denniskliesen
I like Purdy's idea of cutting the flange off and brazing it back on. Much easier to do and I'll do that to the next B manifold. Thanks Purdy!
Old 08-10-2018, 05:22 PM   #11
Purdy Swoft
You are very welcome .
Old 08-11-2018, 05:14 AM   #12
Dave Slater
Dave Slater's Avatar
Purdue, would you know the Venturi ID measurements of the two "B" ones. I would like to know which one I have. Thanks Dave
Dave Slater is offline   Reply With Quote
Old 08-11-2018, 11:51 AM   #13
ursus
22mm I.D. for the Model B and 20mm I.D. for the Model A replacement. They are otherwise interchangeable.
ursus is online now   Reply With Quote
Old 08-11-2018, 12:04 PM   #14
Charlie Stephens
Sacramento Vintage Ford has (or will soon have) the bolts that allow the carburetor to be rotated under part number 5112. The part is not in their catalog, call them.
Charlie Stephens
Old 08-11-2018, 12:35 PM   #15
Purdy Swoft
Dave , I'm having problems finding exact sizes of the two venturis that could be used with the model B carbs . If it has the same inside diameter as the model A venturi, it won't be the one that you want to use. Try Dave Renner at Renners corner , He should have the parts and dimensions PH 734-428-8424
Old 08-11-2018, 02:34 PM   #16
Benson
Benson's Avatar
Purdy,
The Zenith Model B carb for the Model B engine uses a 22 mm (.866 inches ID) Venturi.
The Model A version of the Model B carb uses a 20mm (0.787 inch) Venturi.
Benson is offline   Reply With Quote
Old 08-11-2018, 03:46 PM   #17
Charlie Stephens
Just got a call From Dave Renner and he has those bolts that allow the carburetor to be aligned when using a B carb on an A manifold, rennerscorner.com, (734) 428-8424. His part number is B 9510-SS. He is a small supplier that specializes in Model B Ford parts in case anyone is into that kind of thing.
Charlie Stephens
Old 08-11-2018, 04:42 PM   #18
Purdy Swoft
Originally Posted by Benson View Post
Purdy,
Benson ,
Thanks for the info . Its hard to tell the size when buying B carbs at swap meets . I've got one of the model A replacement venturis for the model B style carbs that I sometimes use for comparison when working on model B carbs . Its good to know the exact sizes . Thanks again .
Old 08-11-2018, 04:49 PM   #19
Purdy Swoft
Thanks Ursus for the info . I misplaced my measurement info and have been using a used venturi for comparison. I will write this info down and try not to lose it again . Thanks , Purdy .
Old 08-11-2018, 09:15 PM   #20
Benson
Benson's Avatar
Looks like I missed Urus' post 13 with same info I posted.
I was posting from the tiny screen of cell phone while over at the hospital (interruptions)
